Results 1 to 9 of 9
Thread: YT125 upgrades
    Dec 2010
    Moorhead, Minnesota
    101
    YT125 upgrades
    I am planning on buying a 1980 yamaha tri moto yt125. If I could only do 1 modification on the trike, what should it be?
    Baltimore, MD
    6,088
    Chang the front end out for the yt175 front end. The 80 and 81 yt125 don't do well with the yt175 top end change over as the clutch pack is way too wimpy and you can't change the clutch pack out cause the 80 and 81 engines are different than the 82 and later engines. Also the shift rods aren't the greatest either.
    Nicholson 500x (Project)
    Nicholson 185s
    PK Racing Suspension 70
    A+ Inc Suspension 70
    AWS Aluminum 90 frame
    Dec 2010
    Moorhead, Minnesota
    101
    how much does a yt175 front end usually cost, and where are some good places to pick one up? also, can you use front ends from other 3 wheelers or dirt bikes, or would that be too hard to get it to fit and function properly?
    Last edited by fenderbender713; 01-01-2011 at 12:29 AM. Reason: did not want to be a post whore. haha
    Baltimore, MD
    6,088
    You can try putting an ad in the classifieds on here looking for a yt175 front end. Ebay can be a good place. A yt175 front end is a bolt on, meaning no mods for it to fit. Prices for the yt175 can vary. You need to get the yt175 front wheel and brake assembly as well as the front end. Plus you have a brake cable and spring and adjuster nut as well that goes along with the front end. Then you have a different shroud than what is on the yt125. But it makes the trike ride a whole lot nicer than the hard front end. The extra brake is nice as well. There are no other front ends that will just bolt on.
    Nicholson 185s
    Nov 2009
    1,147
    I would recommend picking the trike up. If your winters there are anything like ours the YT125 and YT175 are a blast. Seems like they were more common up north than in other areas and I have had no problem finding parts and a few whole trikes. Not the awesome NOS stuff that VealMonkey finds but there are lots of the old Yamaha's around just waiting to be resurrected.
    Dec 2010
    Moorhead, Minnesota
    101
    yeah i think i am going to pick it up tommorow. I think its quite a steal for $150
    Baltimore, MD
    6,088
    Just remember, there is not much you can do to those earlier yt125 engines without it causing alot of problems. If you want to build up an engine, you would need an 82 and later engine.
    Nicholson 185s
    Gold Hill, OR
    1,295
    Also they changed the shift pattern to all up instead of 1N2345. My 81 YT doesnt like to upshift/downshift past neutral. Probably a poor design with an auto-clutch.
    Joker 90
    1981 Yamaha YT125
    1986 Yamaha Big Wheel 80
    1986 Kawasaki Tecate KXT500
    1987 Kawasaki KXT250B2
    2005 Yamaha YFZ450
    Wichita, Kansas
    1,361
    Makes me sad knowing my 125 is probley an 80 or an 81. It has the 1n2345 shift pattern also. Oh well, it's a trike i let people learn to ride on anyways.
    Now if i rebuild my spare 175 bottom end... I saw that 125 cranks are cheap and should be the same as the 175 - damn if i could only have a stroker for it instead >.<
