I want to replace my rusty drive chain. Is the 520X88 the same as my stock one? Also can I use a 13 tooth front sprocket with that chain? How much of a difference does that make in top speed?
 New to the board
						Arm chair racerNew to the board
						New to the board
Yes, 520x88 is the correct chain. 13 tooth front sprocket will work, just have to adjust the chain tension. It'll give you more top end.
'85 Honda 200X
'85 Honda Big Red 250es
'85 Honda 250R
'82 Honda ATC 70
'87 LT500R Quadzilla
BRUP!!!!!!!!
You need a 520 chain, the 88 is the number of links. I don't remember how many links a 200x uses but normally I just get 120 links and cut the extra off. If you get extra links then your safe if you have a longer swing arm or different size sprockets then stock.
WWW.HREATV.COM
 New to the board
						New to the board
						ok thanks, approx. how many more mph does the 13 tooth give you?
About 5 mph as long as the motor has enough torque to pull it.
Custodian of:-
85 Tri Z - need rear plastics to go with Mosh seat cover
83 200x - engine being rebuilt but lodging with a friend
85 250r - also lodging with a friend until I have a new shed
....and a different kind of Z
here is the chain you need 3 Loading... SKU: 40530-965-003
CHAIN, DRIVE (DID520VS-88L) 1 $87.44
1985 ATC 250R.Team Red Trike
