Results 1 to 8 of 8
Thread: 200X clutch removal
    Feb 2009
    Liberty NY
    49
    200X clutch removal
    What is everyone using to remove the clutch nut as far as holding the sprocket. In the manual it shows a universal holder for the sprocket. Thanks
    Dec 2005
    Wisconsin
    1,141
    3/8 inch impact with the proper clutch nut removal tool. Hold the clutch by hand and turn it off, makes easy work of it. If you don't have an impact put a penny between the clutch basket gear and the crank gear and turn it loose.
    YTM-200, Wheeling machine!!!
    1985 Honda 200x...
    ...Just a simple mild 200x
    Sep 2007
    100mi west of Chicago
    3,582
    Impact gun is the way to go if you have one or you could take it to somebody's house that has one. It spins it so fast you don't even really have to worry about holding it with an extra tool.
    Rob
    Feb 2009
    Liberty NY
    49
    I do use a impact to remove the nut but what is everyone using to hold the sprocket when installing the nut so it can be torqued correctly.
    Sep 2007
    3,582
    Ok to tighten yes you can use the penny trick like wikid said above
    Rob
    Nov 2009
    1,147
    You can make the poorman's impact wrench and just smack the end of the ratchet with a wood block. It actually works surprisingly good. Or give the ratchet a quick sharp chop with the palm of your hand.
    The socket for the clutch is available from BikeBandit and lots of other places.
    Also if the engine is still in the frame if the service manual calls for a sprocket holder I will just leave the chain on and have someone hold the rear brake.
    al
    39
    does the nut turn counterclockwise?
    ctbale is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    anchorage alaska
    289
    yup, ccw to remove, the washer is a spring washer, will say OUTSIDE on it when you put it back together
