are their an with fuel injection or are they all carburators? if not can you get a fuel injection kit?
1985 honda 200s aka "bones" only orignial part from the bike is frame the rest is off a different 200s 1984
They were all carbed. For a kit i believe it would require a new cylinder head designed with an injector. As well as somthing to time the injection pump. Most likely not a kit out there. Best bet would be to fit a modern engine in the frame
Itd be cool if someone built a fuelie kit like they do for the banshee. but the extra weight would be a down side
you might be able to use parts from a new crf 450 probably easer to use the whole motor
unless you count a windex bottle filled with gas being squirted into the intake as injection, no.
Build a hybrid ltr, yfz, or kfx 450. The ltr has been done already and was at TF10. If you're a crafty enough person and feel the desire to have an injected trike, it's up to you to make it happen.
86 200x, 1st gen 200x axle,400ex hubs,fmf megamax2 muffler
Three wheeler guys probably have the biggest balls out of all the ATV/Motorcycle riders. You just have to be a little twisted to ride them, and you have to be a great rider to do so.
'let those who slide decide'
Yea I don't like the hybrids. They look like a cross of a motorcycle and quad actual trikes don't have that look to them but I might try fitting a modern motor to the frame. I got a spare frame
