Results 1 to 15 of 15
Thread: Do I need gear oil or regular oil for the crankcase (tecate)
    Sep 2003
    53
    My uncle put regular motor oil in it....I was told it was supposed to be gear oil....Now my clutch doesnt work....I can pull the cltch and it will still be in gear....If I need gear oil what kind/weight? thanx
    May 2003
    140
    tecate case oil 10-40 sae ,don't use gear oil it's to thick
    ok
    cedar falls, IA
    546
    I think the manual calls for 10w30 motor oil, but its all the way upstairs and outside in my garage and I dont feel like getting up to double check. maybe someone else on here wont be as lazy as me. ----Joe 8)
    The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself?
    85 atc350x ('05 christmas present to myself)
    84 tecate (my baby)
    84 honda 110 (lil buddy)
    81 honda 70 (daughters ride)
    86 lt250r (sold for parts) R.I.P.
    Rittman, Ohio
    6,276
    Standard 10w30 or 10w40 is fine. Dont use automotive gear oil, as its way too heavy. They do make expensive 2 stroke motorcycle gear oil that some people swear by, such as Bel-Ray Gear Saver, but Im personally not a big fan of them.
    May 2002
    610
    Use high dollar gear oil....That's why they make it.
    Sam from Florida
    1985 BIGRED $ 200X
    Mar 2003
    West Monroe, LA
    847
    I use synthetic Silkolene gear oil, never had any tranny or clutch problems.
    Sep 2003
    53
    Well my uncle put regular motor oil in back in the day...Now I think the clutch is gumed up..So Im going to attempt to take the clutch out today...Wish me luck!
    Sep 2003
    53
    Got the clutch out and everything...Now Im going to go and buy some gear oil....10w40....Thanx guys!
    HypnotizeMindz's Avatar
    HypnotizeMindz is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Miami, Fl
    344
    tecate
    u have to pull the flywheel to get the case off to mess with the clutch ??
    «°¤.::JaKe::.¤°»
    bbechtel16 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Halifax, PA
    400
    Just make sure if you use a synthetic that it is safe for wet clutches (contains no friction modifiers).
    -'86 ATC 250SX: No longer mine... Complete 350X front end, Corbra Megaphone system, 350X carb with UNI dual stage foam & outerwear bolted driectly up, Powroll/Rocky 260cc bore 10.5 to 1 compression piston.
    May 2002
    Texas
    2,670
    Re: tecate
    Quote Originally Posted by HypnotizeMindz
    Not on a Tecate. If you have to pull the flywheel, your going in from the wrong side! Definitely taking the long way around.
    I like Bel-Ray gear oil. It seems to help with grabby clutch, which is a trade mark of the KXT250 Tecates. Tecate riders know what I'm talking about.
    Right now I've got 10w30 in my Tri-Z and my 86 KXT.
    1986 Tecate
    1984 Tecate
    1985 Tri-Z
    1986 ATC350X
    1985 ATC250R (2)
    1985 ATC125M (2)
    1982 ATC70 - Original Owner
    175 TriMoto Frame with Pro-Tec Rear Suspension
    3-Wheelin' since '82
    Miami, Fl
    344
    gear oil
    this is my first tecate... my first 2 stroke...
    i have to pull the flywheel.. to split the case...
    any tips on pullin the rotor ?
    «°¤.::JaKe::.¤°»
    cedar falls, IA
    546
    so bel ray will fix that huh Jeb. I never could figure out why that clutch grabbed so hard. s.o.b. sometimes trying to take off slow in 1st gear lol. very hard to feather.
    84 tecate (my baby)
    Sep 2003
    53
    you dont have to pull the flywheel or split the case to get the clutch out....
    Here is my next issue! lol The alternator is froze! I need to pull the flywheel off....The alternator is all rusty looking....Anyone know how it could have gotten rusty?
    Southern MN
    1,875
    crap always seems to get in there somehow. I had mine swapped onto a diffrent bottom end the other day, and when I took the flywheel cover off, a whole bunch of little rocks came out, and it was really rusty in there. I lubed it up, put it onto the other bottom end, and now its good to go! Im suprised my stator didnt get all chewed up from those little rocks. the front side of my flywheel sure took some abuse. lol
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
