Results 1 to 10 of 10
Thread: PLEASE HELP Changing Connecting Rod+Bearings
    2hundredx's Avatar
    2hundredx is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2008
    Missouri
    392
    Exclamation PLEASE HELP Changing Connecting Rod+Bearings
    Can some one please step me through replacing my connecting rod on my 85r PLEASE. My manual says nothing about it. Right now ive got the crank out looking at it. Thanks alot! Collin.
    My first 3wheeler- http://i290.photobucket.com/albums/l...ite200x002.jpg
    Current 3wheeler- 1985 250R
    "Your four wheeler must be fast 'cause you were haulin ass when I passed you on three wheels"
    skidoo99 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2010
    nh
    267
    im going to be doing mine on my 84r soon as well. i found a local small engine shop to do mine. was hard to find anyone to do it cause they said the time it would take em and the amount they would charge wouldnt be worth it to them. if anyone else has done this i would be interested in what they may have paid so i have something to go off of.
    2hundredx's Avatar
    Feb 2008
    Missouri
    392
    i found a shop in kentucky that will do it for my 85r for 100.00 if i send them a new rod kit and 169.00 for them to install a pro-x rod kit. Im leaning toward the 169.00. Sounds like a very good deal to me.
    Aug 2004
    Ab Canada
    4,368
    You need to bring it to a machine shop that has the proper tools and Knowledge to do it...Think honda's are a little more complicated cause they have a Tin plate around the weights themselves. Should be able to find a reputable shop around there to do it.
    1985 Tri-Z-
    Nov 2010
    nh
    267
    100 bucks, sounds good to me
    Dec 2007
    Quebec,Canada
    1,014
    I always change my rod myself,when I change connecting rod for my customers it's habitually 50$....it's a 30 minutes job normally....
    1986 ATC500X
    1985 ATC250SX
    1985 ATC200X
    1985 ATC250R
    1986 ATC250R
    1984 ATC250R
    1981 ATC70
    1984 ATC70
    1985 ATC70
    Custom built ATC70 / 250R laydwon swap
    1986 ATC250SX FATCAT
    2hundredx's Avatar
    Feb 2008
    Missouri
    392
    I thought that you have to true up the crank after putting a new rod in?
    Aug 2004
    Ab Canada
    4,368
    Quote Originally Posted by 2hundredx View Post
    Yes it needs to be trued...Need some roller v blocks and a few dial Indicators, a few brass s...feeler guage's fixtures for the press to take it apart and put it together...Sounds like Atc500x is set up good.
    1985 Tri-Z-
    2hundredx's Avatar
    Feb 2008
    Missouri
    392
    must be lol
    Dec 2007
    Quebec,Canada
    1,014
    I'm using a late,holding the crankshaft on one side,and turning by hand with the dial indicator,and adjust with a brass
    1986 ATC500X
    1985 ATC250SX
    1985 ATC200X
    1985 ATC250R
    1986 ATC250R
    1984 ATC250R
    1981 ATC70
    1984 ATC70
    1985 ATC70
