Developed a strange shifting issue with my 85 ES after plowing the last big storm... All the gears are there, no strange grinding or anything of the sort, new clutch installed a little while back, good oil, and the shifter pawl is tight on the shaft... There, we will rule out all the common issues. The thing I have developed is difficulty getting into first. From neutral, I have to lift way to the very top of the shift pawl's throw, to get it into gear... Sometimes takes 2-3 attempts. After that, all the gears are totally normal to get into. Just from neutral to first can be a p.i.t.a.... Anyone got any ideas?
