i was looking at another build thread on here looks like he guy put 200s forks on his 90. so i was wondering if i can put 200s forks on mine. does anyone no if they r bolt on and if i can still use the 90 axel?
I believe most of the utility ATC's front suspension forks will fit on, but don't quote me on that.
LED obsessed
2015 Yamaha FJ-09
I have done this mod several times it will work fine but you will need the 200s axle also the steering stops will need modifiing or cut off then new welded on unless you want your tank to act as steering stop ,not good damage to tank also over steer if done correctly woks good front susp. help smooth the ride and takes viberations away fromhands ,wrist ,good luck
the one thing I kinda learned with most hondas is...most front ends with swap on to other bikes/atc. for the most part, most of the ATC front ends have the same steering bearing size. the way I do it is go to allballs bearings, and see what size bearings your 90 take, then see what size bearings a suspention atc takes, if they are the same, chances are it will fit, assuming the stem is long enough. but like I said honda is pretty good about that. I even bolted on with very little modifications, a front end from a 2005 honda on to my old 90 honda, I did the bearing check, then dropped it on, now I got cartridge forks and big brakes!
F.U.2 RACING
Atc90, bandito frame
Atc185 x2
82 250 (300 kit)
83 250R
200ES Big red
Atc200X (with lifan motor)
the 200s have a diffrent axel set up to right? so i would need the hub and rim?
You want the complete front end. Forks, axel, hub, wheel, brake setup. etc. Headlight mount too if you can get it. I still haven't figured out a good way to mount the stock headlight back on. I used the 90 bars and bar mounts but the spacing isn't correct. Inspect the forks good if you can cause both the ones I picked up were tweaked.
2) 1977 Honda ATC90
2)1985 Tecate
2005 Banshee LE
01 Honda 300EX
74 Suzuki TC100
66 Honda 305 Scrambler
does anyone know if the 200x tree and forks will work there is a guy on craigslist that has them
I think I only took a pic of the parts...Don't think I have one of them on the trikes..
2) 1977 Honda ATC90
2)1985 Tecate
2005 Banshee LE
01 Honda 300EX
74 Suzuki TC100
