Results 1 to 8 of 8
Thread: Aftermarket bars for ATC 70
    pismorat's Avatar
    pismorat is offline At The Back Of The Pack Arm chair racerFirst time rider
    Dec 2005
    San Diego
    207
    I found a set of bars on craigslist that were used on an ATC (unknown type), but I am thinking of putting them on my ATC 70. They are about 30" wide and 7.5" tall...will this work??
    6,811
    Should but your throttle cable might be to short .
    pismorat's Avatar
    Dec 2005
    San Diego
    207
    Where would I get longer cables...probably for throttle and brake?
    Dec 2002
    deer park, texas
    2,336
    On my 70 build i used a set of moose bars for a cr250. It had the bend on wanted but of course my new cables were a bit too short. I ended up cutting 2" off of each side of the bar, then put my handgrips on. This made the cable long enough and also made the reach less for the kiddos.
    Never argue with an idiot. They will bring you down to their level and beat you with experience.
    Calling an illegal alien an undocumented immigrant is the same as calling a drug dealer an unlicensed pharmacist.
    1981 Wife ( Project)
    springville, PA
    6,185
    extended brake and throttle along with anything else you need http://www.sterdyproducts.com/produc...?idCategory=32
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
    I run ATV high Pro-Tapers.....
    No cable changes, all stock.
    Jul 2008
    MD
    911
    I am running Pro Taper mini bars on mine. Cables are just long enough.
    pa
    137
    i am running an old set of bmx bars and i made the cables out of a bmx brake cable. dratv.com sells the solder on pieces for the end of the cable which goes in the carb.
