I have a 1980 honda 185 three wheeler my kid was riding it she said it made a ping sound and just quit. It does not have any compretion I tore it apart the piston and rings look ok. What else shoud I look for?
stuck or bent valve
Yeah take a look at the head. Are either of the valves open slightly? I had a quad with a bent valve and you could see it was open all the time when looking at it
Rob
Gotta be something with the head. Like everyone else said, check the valves.
Ride: 1986 Honda ATC 200x
Following Mods Done:
-Anodized blue block-off plate
-Factory head light and master cylinder guard
-ITP mudlite SP rear tire/Chengshin turf tamer front
-DG reverse megaphone exhaust
-UNI airfilter
-Moose bars/Protaper Grips/MotionPRO twist Throttle
-CEET classic ATC blue seat cover (should of sent it to mosh :-(...)
-Tuned Carb with a 125 main jet
-COMPLETELY restored gas tank
-RED/WHITE PowerMadd Handguards
-1/4" thick aluminum swing arm skid plate!
Maybe camchain broke?
80' Honda CR80R
78' Honda XR75
77' Honda CT-70
74' Honda CT-70
75' Yamaha GT80 Enduro
76' Kawasaki KZ900
73' Kawasaki H1-500
76' Kawasaki H1-500
thanks I will check the valves. when I took it apart the cam chain was off the sprocket I thought that was the problem I put it back on and put everything back together but it still did not have any compression
that chain cant just be put back on the spocet its gota be timed with the fly wheel sorryif you did but you didnt say anything
if that chain came off and there was a ping sound i bet my ass you have a bent valve
