looking for some answers i just bought a 1981 yamaha two stroke had a few problems to work out but i can not seem to get it to stay running without holding the choke all the way open i cleaned the carb and still the same problem any ideas
Check your intake boot, make sure it's not cracked. Easy solution is to take carb cleaner, and while the motor is idling spray a bit on the intake boot itself and see if the motor smoothes and speeds up.
old yamaha carbs suck for that i had a mx 80 2 stork with a auto pop up choke never ran without it wired down even after a carb kit and difrent jets ran fine with the choke even right plug color
probably richen it up a bit, my YT175 is way happier since I have done that.
I got the machine to idle without the choke on now, but when I throttle it up it sticks high idle if I pull out the choke it goes back to an idle. If i unscrew the choke can that also be cleaned what should I be looking for to see if the choke is bad or needs to be replaced .
exact same as mine did got new choke parts didnt help at all but my motor ran great with it so i left it
