Results 1 to 7 of 7
Thread: 1986 Clutch Replacement Question
    Finger Lakes Region, NY
    613
    I am thinking of buying a 86 350X that is starting to slip. I haven't ever changed a clutch. Is it a difficult job as far as getting to it and approx. time frame? Also where would be the best place to buy it as far as cost and quality. Is there a better replacement than the OEM? Appreciate any tips and pointers!
    ...the branch cannot bear fruit of itself, unless it abide in the vine...
    Aug 2010
    Southern Oregon Coast
    932
    If you're just replacing the discs and friction plates, changing the clutch out isn't that big of a deal. As far as parts go, ebay is your friend. I think you can still get them from local parts shops too. I put a tusk kit in my 250r and it seems to be holding up ok, from what I've heard/read EBC seems to be a quality brand too...
    Also, go here: http://72.52.143.80/~trikes/ and d/l the 350x manual. It will tell you how to do it all.
    when you pull the clutch cover,, dont loose the o ring for the oil pump!
    TommyBoy1971's Avatar
    TommyBoy1971 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Quinton, VA, United States
    161
    http://www.dirtwheelsmag.com/ME2/dir...8A805D790461D7
    This link you might find helpful, basically all these clutches are put together the same way. Type of oil used is important, as well as soaking your fiber disks. There is a TM here on this site for the 350x, It shows specifics for that one. You will want to use a TM that is specifically for your bike. It's pretty quick and easy process though.
    Oct 2007
    Minneapolis mn
    4,067
    Not a bad project to do... Buy a decent quality clutch, and some fresh springs, and you will be back in business...
    They only need to soak an hour, if you lay it on the side, you don't even have to change the oil.......
    You'll need an air impact to loosen the nut and zip it back on.
    I'm a heavy clutch user, I only run OEM or BARNETT and use new springs everytime. They last me 10 years or more.
    613
    Thanks, appreciate all replies. I want the best for sure, more time riding, less time fixing! I will replace the springs as well as watch out for the oil seal. The oil I'll change also. Again, thanks for replies and tips!
