Results 1 to 12 of 12
Thread: 85 r cdi
    Apr 2010
    oklahoma
    27
    85 r cdi
    does any one have a cdi box for 85 r or does any one know how to test it to see if it is good?
    osoyoos bc canada
    1,057
    you need a very high quaity multimeter to test them and its still a huge pain in the @$$ its easyer to test every thing else
    if nothing else is broke get a cdi i think rm stator on ebay might have one they got good prices
    Apr 2010
    oklahoma
    27
    thanks i think ive narrowed it down to the cdi
    Jan 2011
    Choctaw, OK
    2,755
    What makes you think its the CDI?
    Apr 2008
    NW, IND.
    842
    +1.... on the right tester or it will give you bad readings.
    80' Honda CR80R
    78' Honda XR75
    77' Honda CT-70
    74' Honda CT-70
    75' Yamaha GT80 Enduro
    76' Kawasaki KZ900
    73' Kawasaki H1-500
    76' Kawasaki H1-500
    bigbadktm's Avatar
    bigbadktm is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    San Diego, CA
    437
    the manual i have says that a tester is not recommended, and the sad part of the 85 is that nobody makes a replacement cdi for it. they make em for the 86 though if you wanna change your wire harness over, went through that hassle and bought a used one off of ebay
    1985 250R
    FMF pipe and silencer, K&N, 4" extended swingarm
    Mar 2003
    Australia
    1,919
    Im pretty sure someone does make an aftermarket one for the 85. Pretty sure I seen them on ebay not long ago.
    1980 ATC 70 Needs Restoration
    1985 ATC 250es Fully Refurbed
    1986 ATC 350x Mint Original
    bigbadktm's Avatar
    San Diego, CA
    437
    wow i stand corrected, it must be very new because they didnt have them when i was looking for one, or I would have bought new
    1985 250R
    Ironbnder's Avatar
    Ironbnder is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Alexandria, La
    363
    Most CDIs can be tricked to work a little as a test by heating them up with a hair dryer or getting them cold in a freezer. Try this and I bet it will fire up and run one more time if it is in fact the cdi that is bad. It will still have to be replaced. Heat works better than cold.
    FEEDBACK@ http://www.3wheelerworld.com/showthr...-for-Ironbnder
    86 250R
    86 350X
    87 250sx
    85 200x/cb350 custom
    81 185s/200x/250r custom
    79 atc 70
    Mini-Trail z50, 110cc Pit Bike
    and many multi-wheeled machines
    osoyoos bc canada
    1,057
    honda cdis are veary interchangable you can plug a 00 xr 70 cdi into a 85 350x and it will work fine the plugs are even the same
    Apr 2010
    oklahoma
    27
    put new coil on and no fire and tested the stator by ricky stators specs and its good so must be the cdi?
    bigbadktm's Avatar
    San Diego, CA
    437
    i replaced all three of the above at the same time and voila I had spark
    1985 250R
