Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 37
Thread: 200X engine experts
    Crest California
    3,014
    Exclamation 200X engine experts
    Alright so last night I was cruising home with my buddy on our 200X's (just cruising, not running them balls to the walls or anything) when right before I turned on my street my engine lost all power and died on me. Sounded much like my XR200R's engine when it overheats (sounded like a gear grinding), so I sat and waited for about 20 minutes for it to cool enough to fire up and run home, except it didn't free up. Had to push it about 1/4 mile uphill to get it home, where i parked it for the night.
    Come to find out it was still ceased in the morning, so I stripped the engine out of the bike and now have the topend all apart on my workbench. After I got the head off I pushed on the piston to see if it was stuck, and it slid right down. Put the kicker back on and it's like nothing was wrong Cranks up and down just fine, but there was no way I was going to put it back together without consulting more experienced gearheads.
    Also I drained the oil, and barely anything came out, but it was THICK black- I had just done an oil change about a month ago with 10W-30 oil, and filled it up to the top of the dip stick line, so either it's burning oil, or it's sludged up inside.
    Here's pictures:
    I am thinking I will need a set of new rings and then the gaskets?
    http://dratv.com/strisetat.html
    http://cgi.ebay.com/ebaymotors/Honda...s#ht_780wt_877
    Also I'm wondering if anyone knows what cam this is:
    The guy who sold it to me says it's an XR cam, but is there a way to tell??
    LED obsessed
    2015 Yamaha FJ-09
    Dec 2010
    garland, tx.
    52
    sounds like you got it hot and you need a bore and piston too. not too sure why or how it got hot. i'm interested to see what everyone else says.
    heat would explain the black oil and why the piston expanded and seized and scared the cylinder like it did. i guess some how you were running it so lean it got that hot. maybe a lean mid range mixture? or maybe it needed a top end anyway and thats where all your oil went and why it got hot. valve guides? was it smoking?
    Crest California
    3,014
    Quote Originally Posted by mykwillis View Post
    It wasn't smoking, and it hasn't smoked ever since I got it. Also the plug came out a very dark dark brown color, like burnt caramel, so I'd think that it was running rich?
    Also, I didn't seem to mention it, but we were riding for probably 45 minutes or more, but half of the time was cruising downhill, letting the engine idle.
    LED obsessed
    2015 Yamaha FJ-09
    Slingblade is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Alabama
    258
    If it didn't have much oil in it, that would explain it. She quit oiling up top. what does your cam journals in the head look like? Look's like she got mighty warm.
    Nov 2006
    Huffman TX
    891
    yea, i checked my oil the other day afte3r riding all day and i didnt have enough oil to touch the dip stick, and I had no choice to ride it home and I was so nervous.
    TRIKES
    1987 200x -First Trike-
    82 185s-SOLD!
    82 250r-SOLD!
    85 250es -the lil red hulk
    Quote Originally Posted by Midnite_rider View Post
    I like the outlook..... It ran fine before it broke!!!! it was flying before it exploded!!!! it was like new until I tore it up!!!!! LOL She was a virgin until last night??????
    Crest California
    3,014
    Still doesn't explain where all the oil went. Nothing was leaking, and it wasn't smoking...????????????????
    Here's some more pics of the topend bits:
    LED obsessed
    2015 Yamaha FJ-09
    louisiana
    1,499
    you oil pump quit pumping,could be from lack of oil,or just went bad.
    Signature pic removed,becuase of no helmet.
    200xranger's Avatar
    200xranger is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jun 2007
    St. Louis
    207
    i had a 200x that locked up because the oil hole in the head clogged and the cam bushing seized to the cam. just a thought. good luck
    Three Wheels Are Better Than Four!!
    My Rides:
    85 250r atc
    85 tri z
    2012 honda rincon 680
    Crest California
    3,014
    Well I got some good news. My neighbor (who is a mechanic at the local Mercedez Benz dealer) happened to see me working on the engine so he came over to check it out. He took a good look and confirmed that it's burning oil, and said just to put some new rings and gaskets on.
    So that's the good news for today for me. Now to get some rings and gaskets
    LED obsessed
    2015 Yamaha FJ-09
    Dec 2010
    South Eastern Va
    123
    From the way the bore and piston look..... I would first do a quick hone on the piston bore and see if the scratches come out. If they do, you are luck! I then recommend a new piston, rings, and a top end kit. But It looks like you need the bore punched to the next size and get a new piston to match.
    Mar 2007
    Texas
    5,045
    let me save you soem $.
    your entire top end is JUNK. the oil pump is now JUNK...
    go on ebay, get a good jug and get a good pistin and head. (some of us hord 200cc parts so post up in the classifieds someoen may chime in.) figure on spending about $80-$100 on a good top end that needs a new piston.
    if you wanna cheap out, get a 200x piston and cam. if you wanna get good power, get a wiseco 10.25:1 piston and web cam. (piston is $120 and cam is $85).
    have the jug bored and hones to new piston size so that means measuring the jug to ensure you order the next sized up piston and your set.
    good luck. no point trying to save a jug that's mushroomed at the bottom, the base is cracked is how that happens.
    ALWAYS check oil levels.......
    ________________
    https://www.mikesatvfix.com
    Crest California
    3,014
    Quote Originally Posted by oscarmayer View Post
    Well that's not saving me ANY money. I think I'll take the advice of my neighbor (who hasn't given me bad engine advice before) and put it back together and see if it runs. What's the worst that can happen? It doesn't run? In any matter i'm going to need new parts anyways, so what's the difference?
    I think I'll just buy another 200X engine if this one turns out to be a lost cause, something with low hours, maybe part out the bottom end of this one (or at least what's useable). Do the 86-87 engines have the same bolt pattern?
    LED obsessed
    2015 Yamaha FJ-09
    Mar 2007
    Texas
    5,045
    nope they do not swap into the eariler frames. compeltely different engines.
    how spend hundreds on a compelte motor when you can jsut repalce the oil pump, clutch plates and top end. if your going to spend $ why not just spend $ on stuff you have too. it's your $ but it will cot more for another engine than to fix yours.
    see if it runs? it may run (sorta) but will never run right and your very likley to ruin the crank and rest of the engine as the top end that is damaged sends shavings down into the lower end and such. That's 1 bad mistake after the one you just did (not checking fluid levels before the ride) if it was a 90cc or 110cc that was a cheepo motor then ok, but the 200x motor is way more expensive.
    ________________
    Crest California
    3,014
    The funny thing is it hadn't been burning oil before. The couple oil changes I have done all spit out the same amount of oil I've put in, so this is something recent...
    FWIW all of the little metal shavings and whatnot in the above pictures are from a bolt that stripped out and I could only get it off by cutting it.
    LED obsessed
    2015 Yamaha FJ-09
    WilliamJ's Avatar
    WilliamJ is offline At The Back Of The Pack Arm chair racerFirst time rider
    Apr 2010
    Poole, England
    157
    I am a race engine builder and tuner (cars mostly). I am sorry to say your piston (and bore) are toast - it must have partially seized in the bore.
    Those are excellent pictures and should be posted somewhere permanent as a reminder.
    The piston will seize for three main reasons.
    1) It is too big for the bore / lack of clearance. (Not checked when being re-built - and you would discover this on the first run after the rebuild so if it wasn't the first or second run it wasn't that.)
    2) It was starved of oil. If the oil pump or supply failed the cam bearings would be the first thing to go because that's the highest point in the oil ways. The cam bearings look fine (slight mark on one but only slight) so its not that.
    3) It got too hot. It definitely looks as though it got too hot - the oil looks as though it has been cooked but its not easy to say from a photo. The cam looks like it got very hot - slightly blued. The combustion chamber also looks like it got very hot - those deposits are typical of an overheated engine. The plug color of caramel usually indicates slightly rich but that's not a problem. It's difficult to be sure without doing a plug chop. When an engine gets too hot the rings don't seal which lets oil past to be burnt and the oil goes really thin so it gets past the rings even easier. The oil never recovers. Check the bottom end crank bearings - they may be okay looking at the way the cam bearings have survived. The head gasket has failed completely - look at the blow-by marks around the perimeter.
    It may well be possible to rebore it - depends on how big the bore is now and if there is enough material left but it looks as though there is plenty in the photo.
    Check all the gasket faces for warp (requires a true straight edge and an experienced eye) and machine or stone them flat if the faces are warped or they may not seal.
    Please do not put it back together without doing the work because when it seizes next time it could wreck the rest of the motor.
    Put a temperature gauge on the thing when it's done and you'll never overheat it again. You can get really small ones with digital readouts.
    Good luck
    Bill
    Custodian of:-
    85 Tri Z - need rear plastics to go with Mosh seat cover
    83 200x - engine being rebuilt but lodging with a friend
    85 250r - also lodging with a friend until I have a new shed
    ....and a different kind of Z
