I just so love these threads. What does "w.e." mean? Have you tried checking the compression? Seems like there is way much more going on here. What about the rest of the trike? Atc90s aren't real powerhouses and messed up wheel bearings or a rusty chain or improper drive chain tension will cause problems as well. Crud in the tank or fuel system. Crappy fuel. Are you running a fuel filter? Have you cleaned out the fuel filter behind the fuel valve? Tons of things can be causing your problems. Improperly set points. Poorly grounded electricals can affect trike running as well.
Nicholson 500x (Project)
Nicholson 185s
PK Racing Suspension 70
A+ Inc Suspension 70
AWS Aluminum 90 frame
