Page 2 of 2 FirstFirst 1 2
Results 16 to 17 of 17
Thread: atc90 help(again)
    Baltimore, MD
    6,088
    Cool, I was just trying to eliminate other possible problems. Sometimes you may be dealing with more than 1 problem. I also guess that you have double checked all your electrical connections and grounding points and your ignition switch? These things can cause problems as well. Just trying to narrow things down. Also you may just want to change out your points and condenser again, just to make sure that isn't the problem.
    Nicholson 500x (Project)
    Nicholson 185s
    PK Racing Suspension 70
    A+ Inc Suspension 70
    AWS Aluminum 90 frame
    osoyoos bc canada
    1,057
    the stiky is in world class help
