i recently picked up a set of the polished wheels on ebay and put new tires on the factory wheels as backups. the backup set (all 3) are not holding air. ive never had this problem after changing tires several times. after spraying with soapy water all 3 leaks are coming from where the 2 rim halfs meet. i cleaned the rims with a wire brush and inspected the O rings as they looked in good condition. i also put some rtv grey gasket sealer to hold the O ring in place and add an extra air tight seal. could these be leaking cause they are not on the atc70? im thinking that if they were on the 70 it would be 3 more bolts holding the rims together making a total of 6, were as there are only 3 bolts holding the rims together. does this make sense??
