Thread: 70 tires not holding air?
    pa
    137
    i recently picked up a set of the polished wheels on ebay and put new tires on the factory wheels as backups. the backup set (all 3) are not holding air. ive never had this problem after changing tires several times. after spraying with soapy water all 3 leaks are coming from where the 2 rim halfs meet. i cleaned the rims with a wire brush and inspected the O rings as they looked in good condition. i also put some rtv grey gasket sealer to hold the O ring in place and add an extra air tight seal. could these be leaking cause they are not on the atc70? im thinking that if they were on the 70 it would be 3 more bolts holding the rims together making a total of 6, were as there are only 3 bolts holding the rims together. does this make sense??
    Dec 2010
    washington state
    681
    GET A EXTRA SET OF HUBS then they will have 6 bolts ,that may solve your problem plus makes tire changes faster one nut and cotter pin . good luck
    Southern MN
    1,875
    I would put tubes in them and call it a day.
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
    Dec 2010
    washington state
    681
    i would slime the #### out of them befoe resorting to tubes ,had tube problem ,the rim rips the valvestem off unless running max pressure ,
    OHIO
    2,857
    Quote Originally Posted by oneroom42 View Post
    Yes they will leak if the 3 other studs are not pulling them together. You should have put new o-rings in....they may have a flat spot and will leak regardless. Try mounting them on the bike first, tighten evenly before you go further. Use a power wire wheel on a angle grinder if you can....the rims have to be very very clean in the groove area.
