Results 1 to 15 of 21
Thread: questions
    jordan_muirhead's Avatar
    jordan_muirhead is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2011
    Monticello, Arkansas
    316
    questions
    i am new to this forum and atcs, i don't know why my 185s is idling high, it acts as if the throttle is stuck, thus the throttle being loos to a certain point
    Nov 2010
    Oshawa, On, Canada
    2,123
    Probably a stupid question, but did you turn the idle screw down?
    Crest California
    3,014
    Did you not see the answers you got in your previous thread?
    http://www.3wheelerworld.com/showthr...ht=#post957120
    Make sure the "LOCK THIS THREAD" box isn't checked before you post
    LED obsessed
    2015 Yamaha FJ-09
    Jan 2011
    316
    none of them worked, and yes i tried the idle screw, i don't know what it could be, i think it might be something with the cable but not sure what, I'm new to these things, but im very interested in them
    Crest California
    3,014
    Sometimes the throttle cable can cause high idling issues. I know with my 200X it causes all kinds of problems if it's being pulled or pushed on.
    Play with the throttle cable a bit, and see if it causes the engine to rev or not. If it does, then there is your problem.
    LED obsessed
    2015 Yamaha FJ-09
    Apr 2009
    Saskatchewan
    119
    So you put new O-rings in then also?
    ATCrider42 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Iowa
    227
    I had a problem similar to this and it turned out to be the slide in the top of the carb was not all the way down. So I sprayed it with carb clean and made sure it was down as far as it would go. Good Luck.
    Crest California
    3,014
    Yeah double check to make sure your slide is closing all the way. Also the clip in the needle should be somewhere in the middle.
    LED obsessed
    2015 Yamaha FJ-09
    Jan 2011
    316
    Angry
    i did not replace the o-rings, where could i purchase some? and its like the throttle is almost all the way out, you can press it maybe a quarter of an inch and its tapped out, therefore i play with the kill switch to take off, thanks for the info, like i said, ive never had one of these before, i learn from hands on experience, ill try to figure it out tomorrow seeing as its almost dark/icon8.png
    Jan 2011
    316
    what is a decent price for a 185s? i hope i didn't pay too much
    Crest California
    3,014
    What you paid for it is all dependent on the condition....
    As for the o-rings, take it out of the intake boot and go to the local hardware store (home depot, harbor freight ,ect.) and match it up.
    If your throttle isn't closing all the way, then you very likely have your carb slide in backwards. The best thing you can do is get us some pictures of the carb.
    LED obsessed
    2015 Yamaha FJ-09
    Jan 2011
    316
    i gave $300 for it, it was my great uncles, it sat under his shed for the past 8-9 years, i cleaned the carb and poured gas in it afterwords and it fired up on the first pull, i just got the title to it yesterday
    Attached Thumbnails Attached Thumbnails 1294682259683.jpg   1294682235030.jpg   1294682226544.jpg   1294682213792.jpg   1294682082727.jpg
    Springfield Mo
    3,309
    You have an air leak if the carb is spotless, you have adjusted the air/fuel mixture properly, the plug is good, and the intake and exhaust valve have been gapped properly. When it is running, spray some carb cleaner around the intake boot and intake manifold. If the engine boggs or revs then you have an air leak.
    RIP Ninja!
    Trike Fest 2011, 2012 Vet!
    Trikes Currently Owned:
    87 Big Red 250es
    83 Honda 200s
    81 Honda Atc 70
    (4) Suzuki ALT 50's
    Yamaha YT 60
    Jan 2011
    316
    I'm going to put a new plug in it tomorrow and check the carb, and change the oil this week, any suggestions on oil? and how many quarts? and I'm rebuilding the carb this week also
    Ironbnder's Avatar
    Ironbnder is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Alexandria, La
    363
    Sounds like the slide is in backwards. Unscrew the cap on top, pull the slide out, turn it 180 and put it back in. You should have full throttle control again.
    What stud25 said about spraying around the intake and carb with carb cleaner will eliminate the o-ring question. If it changes the RPMs any, then you have a leak.
    FEEDBACK@ http://www.3wheelerworld.com/showthr...-for-Ironbnder
    86 250R
    86 350X
    87 250sx
    85 200x/cb350 custom
    81 185s/200x/250r custom
    79 atc 70
    Mini-Trail z50, 110cc Pit Bike
    and many multi-wheeled machines
