Thread: stroking????
    Apr 2010
    slaughter, la
    59
    stroking????
    i read a post where a person put an xr200 rod in his trike. he called it stroked. that doesn't seem right to me because the stroke didn't change, right? the only thing changing is the distance bewteen piston and the center of the crank. if some one could set me straight i would appriecate it.
    Crest California
    3,014
    I believe stroking out an engine is when you increase the length of the piston stroke to create more torque and compression.
    I sold an XR200R stroker engine to a member on here for use in his 200X, so you might be referring to that....
    LED obsessed
    2015 Yamaha FJ-09
    6,815
    Simply put . The connecting rod is installed further out on the crank thus creating a longer stroke . Machining is required to do this mod .
    Nov 2010
    Havelock, ON, Canada
    87
    You have to put a different crank in for the stroke to change. just putting in a longer rod doesn't lengthen the stroke its just a longer rod.
    Feb 2008
    Sedro Woolley, Wa. USA
    61
    http://powroll.com Try this. They take the crank pin out and off drill the pin hole[bigger] to move the big-end center farther
    out. Then they heat the rod and push the ends together to make it shorter and cut the bottom of the piston to clear the crank throws. They make long rods
    for Banshees that change the rod angle [@90 & 270 degrees] and posta make more torque. Yam used to make a long rod kit for the YZ 250s also. clear as mud eh.
    1985 250R bought from Honda mech. in Feb 85
    1986 250R bought in May 90
    Feb 2003
    Australia
    927
    You could have a rod 4 feet long and the stroke would still be the same. Moving the crank pin further out on the crank wheel lengthens the stroke.
