Results 1 to 12 of 12
Thread: 1985 250sx kickstarter issue
    Jan 2011
    Iowa
    51
    hey im new to this forum and we have a few 3 wheelers, but anyway our 1985 250sx has a problem where kickstarter doesn't catch 90% of the time, and the e-start doesnt catch 75% of the time but when it does it knocks quite loudly (only when you are pressing the button, not after its started) the bike runs great but its a hassle getting it started. Any help will be appreciated, thanks
    Dec 2007
    Quebec,Canada
    1,014
    you will need to change the one-way bearing behind the centrifugal clutch,easy to change but don't forget that the clutch nut is LH,clockwise turn to loose the nut
    1986 ATC500X
    1985 ATC250SX
    1985 ATC200X
    1985 ATC250R
    1986 ATC250R
    1984 ATC250R
    1981 ATC70
    1984 ATC70
    1985 ATC70
    Custom built ATC70 / 250R laydwon swap
    1986 ATC250SX FATCAT
    Jan 2011
    Iowa
    51
    Quote Originally Posted by atc500x View Post
    thanks, ive done 5-6 complete engine rebuilds, just wanted to know what i needed, also it has a valve ticking noise in it, ive adjusted the valves but it didnt help, any ideas?
    Pacific NW
    4,255
    oh, valve noise.
    Real hard to imagine how people get them to .003 or 004 and honestly know the difference.
    I got an orig owner 87 br for 200 bucks because someone adjusted the valves with a rusty shovel. The knock from those rockers sounded like a death rod and would make anyone sick from 50 yards when it ran.
    It really should be set at confirmed TDC and they say a bent square drive deck screw is the same size as the adjuster.
    I slipped on a tight piece of fuel line and did it as meticulously as I could.
    Now what I don't want to tell you is the timing chains are not user adjustable.
    So is the tick an exhaust leak?
    chain slap or just a noisy rocker.
    I'd like to know if there's a way to check oil pressure in these things since the cam chain tensioner is technically oil (pressure??) dampened.
    If it's really a valve lash tick, you can run it with the covers off and try holding the rockers down with a rag to take the slop (and tick) out of them.
    Oil WILL try to fly everywhere but that will also tell you if you've got some sort of oil pressure.
    Fresh oil and filter (112 or 113) change?
    Jan 2011
    Iowa
    51
    Quote Originally Posted by drjoe171 View Post
    oh, valve noise.
    I can assure you they were checked with a feeler gauge and not a rusty shovel lol, my dad is an automotive mechanic and has had bikes all his life and we have a manual for every bike we have. Its not like im just a guy in his backyard that knows nothing about bikes. Its been ticking for a while but we have 10+ bikes and never got around to looking at it. My dad is the one who knows about the 3 wheelers and he said the cam chain tensioner could be bad? I cant remember which one but he said he put a cam chain in either the 250sx or the kawi klt 250, i will ask him tomorrow. Im thinking its the cam chain slapping around since we adjusted the valves. I just changed the oil and filter a couple months ago and its probably been ridden 3 times since then.
    Pacific NW
    4,255
    Quote Originally Posted by 93cr250 View Post
    What they say is..
    there might be some way to lace in a new chain without a complete teardown, but even of that's true, they also say the chain rails and tensioner should be changed. I also wonder if the tensioner would go back in if you COULD
    manage to get a new tight chain in there and hope the guide rails aren't too worn.
    Once every 25 years ain't bad if it does have to be done.
    No I wasn't implying you had the factory authorized rusty shovel feeler gauge. bit the only thing I can think of is that the engine was not at TDC so it may have gotten adjusted with the cam lobes pointing down instead of up.on the one I got.
    I had a heck of a time standing on my head trying to get the adjusters to stay put as I tightened them and I think I gave up and got them close and just made sure they had slight motion by feel, and then rechecked them with a feeler gauge.
    If that never happened, I wouldn't have one of the 4,000 87 big reds bolted
    to the floor in my living room ;-)
    I'm not sure what can go really wrong if the chain get sloppy because I really don't feel like changing mine.
    Maybe it just gets embarrasingly noisy and doesn't ruin anything else.
    Hey, maybe your dad has some idea how to check oil pressure in these things??
    If you do go for the chain and guides and stuff, maybe you can post the procedure as I'm also sure you'll come up with some shortcuts the manual won't mention.
    Jan 2011
    Iowa
    51
    I'll see if the manual says anything about oil pressure, and im pretty sure the lobes were facing down (not against the rockers) we actually didnt have to adjust them at all, they were still in spec after 25 years. Im wondering if i can take the chain out through the ignition side seal hole like i did in the xr 100? Anyway i have to finish the xr 100's complete engine rebuild then put a crank in the cr 80, and then before i look at the valve tick noise on this i have to replace the one way bearing so the kickstart will work then put in the new alternator. So it might be a while lol.
    Jan 2011
    Iowa
    51
    hey another question, i was out looking at the 250sx and sometimes when you kick over the motor it turns the e-starter over, it that another sign of the on way bearing?
    1993 cr 250
    1992 cr 250
    1998 cr 80
    1999 xr 100
    1985 250sx
    1983 atc 70
    1982 klt 250
    1985 ytm 200
    1971 z50 x2
    1972 trail 70
    1971 suzuki ac50
    1965 suzuki m-31 x2
    3 or die's Avatar
    3 or die is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jan 2004
    southeast
    198
    I just changed my cam chain. I dought very much that it could be done without removing the top end minus jug. Its a very tight fit.
    The Punisher!
    Jan 2011
    Iowa
    51
    are you on the wrong thread? because that is completely unrelated lol
    1993 cr 250
    1992 cr 250
    1998 cr 80
    1999 xr 100
    1985 250sx
    1983 atc 70
    1982 klt 250
    1985 ytm 200
    1971 z50 x2
    1972 trail 70
    1971 suzuki ac50
    1965 suzuki m-31 x2
    3 or die's Avatar
    Jan 2004
    southeast
    198
    What they say is..
    You must have missed it on #6
    The Punisher!
    Jan 2011
    Iowa
    51
    i havent been paying attention very well...sorry lol
    1993 cr 250
    1992 cr 250
    1998 cr 80
    1999 xr 100
    1985 250sx
    1983 atc 70
    1982 klt 250
    1985 ytm 200
    1971 z50 x2
    1972 trail 70
    1971 suzuki ac50
    1965 suzuki m-31 x2
