Results 1 to 9 of 9
Thread: 250 sx
    Jan 2011
    dallas,nc
    87
    250 sx
    hey all... im going friday to look at a honda 250 sx 1985. all original minus tires. the owner says he has a title for it thats never been titled an all the original paper work from the first sell at the dealership... my question is this... any thing in paticualr i need to be looking for in this machine... im not very familiar with the model itsself.. so i figured id ask around... cant hurt..
    so if anyone has some advice on do's or dont's with this model holllaaa lol
    heres a few pics... not the best but ya get the idea..
    thanks everyone who responds..
    nateClick image for larger version.
ID:	113752Click image for larger version.
ID:	113751Click image for larger version.
ID:	113750Click image for larger version.
    skidoo99 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2010
    nh
    267
    thats a clean looking sx. its a pretty well built machine so they are usually pretty good. i would check the gas tank to make sure it doesnt leak or have too much rust. its got a nice rack and that trailer hitch is the ballz. i searched high and low to find one of them. other than that just check the normal things, oil, lights, shifting. im sure someone will chime in with more
    Jan 2011
    dallas,nc
    87
    he said ( owner) that it had been in a garage for yrs. has had the tank coated so he says.. carb rebuilt an new battery an tires. so we will see said hes had it running for a yr since him acquiring it...thanks for the advice.... for sure. i need all i can get lol
    newfane ny
    1,277
    check swinger bearings, take it for a ride and listen for any noise from the rear diff, even a clicking noise means you will need one soon, check front wheel bearings, check rear axle bearings. pull the drain plug from the rear diff see if its milky. check the oil. see if the engine ticks? make sure the choke works 85`s can be a bugger if it doesnt, they have a cold start issue. check the kicker to see if it works right and the electric start. try the reverse. run it threw every gear. that should cover it.
    Nov 2010
    Oshawa, On, Canada
    2,123
    check the shocks, shifting, brakes, tires, motor, inside of the tank, lights, cables ( ie throttle ), compression, ( should be able to tell when you drive it )
    Jan 2011
    dallas,nc
    87
    ok... thx guys.. ive wrote all these down... anything else??
    Jan 2011
    Iowa
    51
    Quote Originally Posted by skidoo99 View Post
    are the hitches rare or worth anything? our 250sx has one
    1993 cr 250
    1992 cr 250
    1998 cr 80
    1999 xr 100
    1985 250sx
    1983 atc 70
    1982 klt 250
    1985 ytm 200
    1971 z50 x2
    1972 trail 70
    1971 suzuki ac50
    1965 suzuki m-31 x2
    Jan 2011
    dallas,nc
    87
    beats me man.... lol
    beaver bank N.S Canada
    555
    I just sold one for $50.
