View Poll Results: What is the Best Option for a250sx kick start to work in cold or long time not riding
Voters
13. You may not vote on this poll
  • Carb Rebuild Kit
    4 30.77%
  • 250sx 1986 Version Carb
    6 46.15%
  • 350x Carb
    3 23.08%
Results 1 to 15 of 22
Thread: 250sx Carb Vote- Which works Best
    Silverado's Avatar
    Silverado is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2009
    Whitby
    331
    250sx which is the best option to do so that starting in the cold or from just not riding in awhile.
    Sorry for the last poll I forgot to click Public !
    Hmmm ok I don't know how to make the polls show the Vote bars. Maybe an admin can help
    1985 250sx (Lemon)
    1985 250sx (Ruby)
    1985 250sx (Garnet)
    1985 200m (Hunter)
    newfane ny
    1,277
    just get a good 86 carb.
    Oct 2007
    Minneapolis mn
    4,067
    Rebuild the carb... I have no issues with my 85, and havent done the cold start work to it... Read this link. (I know, I know, its .org)
    http://www.3wheeler.org/tech/06161-H...STRUCT1_50.jpg
    Nov 2009
    Okauchee, WI
    555
    I'm with Thorpe. I have a 85 250es and have no cold start problems after a rebuild. First start of the coldest mornings with the choke on it fires up on two kicks.
    '85 Honda 200X
    '85 Honda Big Red 250es
    '85 Honda 250R
    '82 Honda ATC 70
    '87 LT500R Quadzilla
    BRUP!!!!!!!!
    Silverado's Avatar
    Apr 2009
    Whitby
    331
    That is for a 250es. Would it work for a 250sx ?
    1985 250sx (Lemon)
    1985 250sx (Ruby)
    1985 250sx (Garnet)
    1985 200m (Hunter)
    Leonardtown, MD
    594
    I have an 85 250sx and (for me) a carburetor rebuild kit was not enough to fix the cold start problem. Maybe it was the quality of the carburetor rebuild kit? either way, it did not work. For around 20 bucks, a carburetor rebuild kit may be worth it for you.
    I put my 350x carburetor on the 250sx and decided to put a 400ex carburetor for my 350x.
    The 250sx with the 350x carburetor not only gave the trike a performance increase, but the cold starting problem stopped.
    My Rides:
    1985 ATC 250r
    1989 Suzuki LT-160
    Nov 2009
    Okauchee, WI
    555
    I believe the carbs are the same as were the cold starting issues on the '85 250es and 250sx.
    '85 Honda 200X
    '85 Honda 250R
    '82 Honda ATC 70
    BRUP!!!!!!!!
    The 86/87 250SX carbs (Keihin 08 I believe) will start and run the best.
    If you have mods, the 350X carb is the best you can do.......
    Silverado's Avatar
    Apr 2009
    Whitby
    331
    I don't know what mods I would need. I was hoping the 350x would just kinda plug in there. So far the votes are all tied up 2-2-2
    1985 250sx (Lemon)
    1985 250sx (Ruby)
    1985 250sx (Garnet)
    1985 200m (Hunter)
    Leonardtown, MD
    594
    The 350x carburetor will plug in fine. No modifications at all.
    You will have to unscrew the lever choke and then screw in your 250sx switch choke and then your all set.
    the 350x carburetor fit perfect for me.
    My Rides:
    1985 ATC 250r
    1989 Suzuki LT-160
    Oct 2007
    Minneapolis mn
    4,067
    Quote Originally Posted by mtsnieg View Post
    Yep.......
    Worcester, MA
    1,117
    I have a 250x carb on on mine.
    Silverado's Avatar
    Apr 2009
    Whitby
    331
    Never heard of a 250x
    1985 250sx (Lemon)
    1985 250sx (Ruby)
    1985 250sx (Garnet)
    1985 200m (Hunter)
    Worcester, MA
    1,117
    It's a quad that is like the 350x atc. Only 5 speed/with reverse and 250cc as opposed to 350. VERY similar to 300ex.
    Need to find my airbox tube and rebuild the carb, but it's been working since I put it in. Had to cut the choke lever it half as it hit the starter's mounting bolts. But it's nice not worrying about choke plungers.
    osoyoos bc canada
    1,057
    go with the 86 carb there must be a reson honda thought it was better than the old one the 350x carb was desined for more air flow but would be good to after a rejet
