View Poll Results: What is the Best Option for a250sx kick start to work in cold or long time not riding
Voters
13. You may not vote on this poll
  • Carb Rebuild Kit
    4 30.77%
  • 250sx 1986 Version Carb
    6 46.15%
  • 350x Carb
    3 23.08%
Page 2 of 2 FirstFirst 1 2
Results 16 to 22 of 22
Thread: 250sx Carb Vote- Which works Best
    Nov 2009
    1,147
    The one on my 85 works fine, if you were going to replace it I would go with a 350X carb since it would be an upgrade, or just rebuild the stock one. If you get a rebuild kit you want to make sure it has the right jets before installing them.
    A lot of it comes down to money, if you get extra, throw a 350X carb on there, but if not the stock carb will work fine and costs very little to rebuild.
    ovhonda1's Avatar
    ovhonda1 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Sep 2005
    Louisville, KY
    369
    So let me get this straight as i too have cold start issues on my 85 sx. I have a 350x carb sitting around, so I can switch it out to the sx with no modifications for instillation or no modifications to the motor to handle the larger carb? And the chokes will switch out without modification? If so, what can I expect in increased power with the bigger carb? Sounds like a no brainer if it is that easy.
    Oct 2007
    Minneapolis mn
    4,067
    ^^ Its not that easy... The 350X carb is good if you have mods... Exhaust, cam, no airbox, ect. Chokes do not interchange. There is info about fixing your cold start issue in this thread. Part #06161-HAO-305
    Perhaps DC knows what size the cold jet can be drilled out to on these early carbs to fix the problem... (He is the SX/ES motor god!)
    Also, from searching 3ww for a few minutes, guys have been using carb kit# 03-015 from Shindy for 250es and sx 1985, and is suppose to have the updated cold start jet.
    ^ It is not that easy. If you had an aftermarket exhaust and an open airbox lid then I would recommend it. IDK what you have??
    Did I miss the "here are my mods" list?? EDIT - .080 on the starter jet fixes the starting issue. Grease the drill bit, have a ball..............
    It's NOT an upgrade in relatively stock form, your letting more air in, more gas in and nothing that requires it. SOOOOOOOOO, it's my opinion (F the pole) that it won't do much unles you make other chages. At that point, it's a nice cheap upgrade and all you lose is the choke cable.
    Thats my .02c
    Pacific NW
    4,255
    Thats my .02c
    Do you mean .080, as in 80 thousandths for the cold start jet??
    I did one years ago and kicking myself ever since for losing the drill and forgetting the size.
    Thanks
    Silverado's Avatar
    Silverado is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2009
    Whitby
    331
    it looks like the polls is saying go for the 250sx 1986 carb. The 350x sound nice but I don't have my bike moded for what its increased functionality would give me
    1985 250sx (Lemon)
    1985 250sx (Ruby)
    1985 250sx (Garnet)
    1985 200m (Hunter)
    Oct 2007
    Minneapolis mn
    4,067
    Quote Originally Posted by drjoe171 View Post
    Thanks
    Yes. .080 is 80 thousandths... A single drillbit seems cheaper than buying a different carb... (but what do I know) Modifying the cold start jet makes your current carb essentially the same as the 86 (with the cold start fix)
