Thread: 1985/1986 low to mid boggle
    Jan 2011
    so cal
    4
    I just picked up a 1985 250r (my second one) it has a PJ 38 carb and is ported with FMF fatty pipe and power core scilencer I installed a rad reed valve unit and no help with the boggle, I took the carb apart and cleened it up but my next step is to rebuild carb and check the jet #'s while I'm In their what jet size do you think I should run? I've also ajusted the air/fuel ajustmet with no change boggle remains lean or rich.
    Thanks for any help!!
    Alvarado Texas
    94
    There is a really good thread in here by dammit about proper jetting!! It will help you a lot to read it and properly jet your carb to get the bogg out of it! Another thing you can do to help a lot if it is an option would be to get away from the pj carb and get a kiehin pwk carb! The advancements between the pwk and pj in my opinion are night and day and you will be able to feel the power difference. I hope this helps. The thread I'm referencing is titled carb jetting 101 I think check it out for sure its excellent info
    Jan 2011
    so cal
    4
    Thank you for the reply! I'll search for the thread.
    Jan 2011
    so cal
    4
    I took my carb apart and my slow jet is a 58 seems to rich to me and my main is a 160. sence my problem is from off idle to midrange it leads me to think the slow jet is to big at 58.
    What do you all think??
    Thank you!
