Muffler baffle blew out
On my 83 atc 110 I had purchased a used muffler. Its a straight pipe and has a baffle with some padding around a hollow cone at the end of the muffler. The padding is worn and should be replaced. What is the padding? Is it an asbestos type material? Where can I get some material like that to replace it with?
1978 ATC 90
22mm Keihin carb
Ported intake/head
Performance cam
56mm 9.5:1 piston
110 cylinder/crank
110 cylinder/ timing chain
Front drum brakes
Brush guard
Complete rebuild to a 122cc
Complete frame off restoration.
$1400 invested
1983 ATC 110
22mm carb
Ported head/intake
Performance cam
56mm 9.5:1 piston
Complete rebuild to 122cc
$1000 invested
1984 200x
26 mm carb.
CR85 rear caliper
TRX hubs/rims
$871 invested
