Page 1 of 6 1 2 3 ... LastLast
Results 1 to 15 of 81
Thread: 84 cr500r in an 84 200x
    buffalo new york
    46
Name:	Todd's iPhone 129.jpg
Name:	Todd's iPhone 080.jpg
Name:	Todd's iPhone 053.jpg
Name:	Todd's iPhone 051.jpg
Name:	Todd's iPhone 032.jpg
Name:	Todd's iPhone 022.jpg
Name:	Todd's iPhone 006.jpg
    Dec 2010
    Back in VA baby!!
    711
    The downtube modification looks great..you do that yourself? Looks like it's gonna be a nice trike!
    Nov 2006
    southern oregon
    2,338
    Very cool project. The pipe looks like it leaves alot to be desired. What is the pipe from?
    2-stroke lover
    sandiego
    beutifull just beutifull
    Sep 2008
    Buffalo
    808
    hey neighbor, looks interesting
    Tpc 450
    86 250r
    86 350x
    86 200x
    86 250sx
    85 225DR
    (2) 84 YTM
    (3) 85 Atc 70
    Moncton, NB
    106
    Cool! That pipe look like it'll be easy enough to fit without modifying it's length.
    Btw, I always cringe when I see pics of a disassembled engine with a crowbar or sitting near it!
    buffalo new york
    46
    Yes i did the down tube myself. It was a 5" round 1/4" wall tube that i heated and flattened. The exhaust is a DG for a 85 250r that i cut and and turned outward. All the motor mounts are very close to the 200x.
    lazybiker79's Avatar
    lazybiker79 is offline At The Back Of The Pack Arm chair racerFirst time rider
    lakeland FL
    156
    sweet project.. I would love to see it running. It's going to be a crazy bike
    Terryville,CT
    1,616
    Wow such a small frame for a 500 motor widen and lower that bad boy and it would be one hell of a dirt tracker!
    2- 85 250SX's
    1- 85 200X
    3-ATC 70's
    buffalo new york
    46
    Im working on lowering the back 4". I had to move the upper shock mount back to clear the carb. So the bike sits really high in the back. I was looking at buying the 82 250r durablue axle.
    buffalo new york
    46
    Also i am waaaay outa my league with carb jetting. Any thoughts or ideas will be greatly appreciated.
    here
    1,336
    Really cool. And no kiddin', that would make the ultimate ice racer/flat tracker. Cool fab and neat rig!
    buffalo new york
    46
    Some new pics-
ID:	114762 Click image for larger version.
ID:	114763 Click image for larger version.
ID:	114765 Click image for larger version.
ID:	114766 Click image for larger version.
    osoyoos bc canada
    1,057
    i havent seen a 82 axle but ive seen a 83 250r and a 200x the rear cariers are totaly differnt the 200x swing arm dont look veary strong it would be alot better to use a 83 swing arm and axle there built alot stronger it may be better too cause the shok is in the swingarm and it mounts low so it wont be in the way of your carb and you can use a air box and i realy think your
    cr 500 motor will destroy the original swing arm and the chain tenchioners
    here
    1,336
    ^83' swingarm sprockets do not line up, it will not work. And all Honda race bikes have the same tensioning system. They are used in the ATC 500R, bored 350x's (400+cc), and even Tecate (with only 1), and they are not destroyed. Just be careful of misinforming someone as it may be very costly and cause difficulty.
