 New to the board
						Arm chair racerNew to the board
						New to the board
						The downtube modification looks great..you do that yourself? Looks like it's gonna be a nice trike!
Very cool project. The pipe looks like it leaves alot to be desired. What is the pipe from?
2-stroke lover
 New to the board
						New to the board
						beutifull just beutifull
hey neighbor, looks interesting
Tpc 450
86 250r
86 350x
86 200x
86 250sx
85 225DR
(2) 84 YTM
(3) 85 Atc 70
Cool! That pipe look like it'll be easy enough to fit without modifying it's length.
Btw, I always cringe when I see pics of a disassembled engine with a crowbar orsitting near it!
 New to the board
						New to the board
						Yes i did the down tube myself. It was a 5" round 1/4" wall tube that i heated and flattened. The exhaust is a DG for a 85 250r that i cut and and turned outward. All the motor mounts are very close to the 200x.
sweet project.. I would love to see it running. It's going to be a crazy bike
 New to the board
						New to the board
						Im working on lowering the back 4". I had to move the upper shock mount back to clear the carb. So the bike sits really high in the back. I was looking at buying the 82 250r durablue axle.
 New to the board
						New to the board
						Also i am waaaay outa my league with carb jetting. Any thoughts or ideas will be greatly appreciated.
Really cool. And no kiddin', that would make the ultimate ice racer/flat tracker. Cool fab and neat rig!
 New to the board
						New to the board
						 I can fit a square peg in a round hole. Just give me a hammer and duct tape!
						Arm chair racerJust too addicted
						i havent seen a 82 axle but ive seen a 83 250r and a 200x the rear cariers are totaly differnt the 200x swing arm dont look veary strong it would be alot better to use a 83 swing arm and axle there built alot stronger it may be better too cause the shok is in the swingarm and it mounts low so it wont be in the way of your carb and you can use a air box and i realy think your
cr 500 motor will destroy the original swing arm and the chain tenchioners
^83' swingarm sprockets do not line up, it will not work. And all Honda race bikes have the same tensioning system. They are used in the ATC 500R, bored 350x's (400+cc), and even Tecate (with only 1), and they are not destroyed. Just be careful of misinforming someone as it may be very costly and cause difficulty.
