Results 1 to 3 of 3
Thread: Kick start ?
    Jan 2011
    Linden
    10
    Kick start ?
    Ok my ? Is when I go 2 kick start my atc 250 sx 1985 it does not turn the engine over but is I move it like a inch or 2 I will get it to chatch and turn the engine but most of the time it will just slip and the kicker will fall 2 the ground and make a loud ratchet nosie but it the kicker will pop back up. Now if I do the same thing, moving a inch or 2 about half way Down I get it to chatch more than at the top. O haven't tookin it apart yet but wondering if anybody has any idea what it would be.
    Some told me it was the spring but idk if that is it or not?
    Thank for any help
    Silverado's Avatar
    Silverado is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2009
    Whitby
    331
    I think it is just the spring not fully recoiling. Mine did that before I took it apart because the spring was not installed in the little notch. If yours is catching sometimes i think you just need to let the teeth catch and by gentle and feel that it is locked before you kick. Mine is doing that right now , I know exactly what your talking about .
    1985 250sx (Lemon)
    1985 250sx (Ruby)
    1985 250sx (Garnet)
    1985 200m (Hunter)
    Beaver Falls, PA
    2,666
    It's the sprag gear, also called the one-way clutch... very common problem in the 250es/sx.
    Check the link http://www.3wheelerworld.com/showthr...ighlight=sprag
