So i have begun a small winter project of reviving another 85 R motor, and i am just torn about what type of top end i would like to go with .I first thougt i'd just snag a nice new top end kit on ebay maybe a 265 or so but after seeing some of the prices I quickly started giving the original cylinder a little more thought. The motor is a 85 so the crank is a short rod crank , now i was thinking i'd just get a mild port job done to her and use a spacer plate and go with a 87-89 style piston. My question is if I where to do that would that set up be okay ? I was under the impression that when using the spacer plate you needed a different style port job for port timing , but again after searching ebay it seems as though alot of those folks are selling kits with original cylinders and spacer plates.So if this is possible what size plate would i use ? Also would I still use the short rod or replace it with a long rod crank,what configurations work together ? And what are the size lengths of the two rods? So i can check what I have or know what i may need.Another question is I planned on getting a coolhead for the motor so what size cc dome would be in my best interest with that setup and pumpgas?
Any input and advice would be greatly appreciated as i am preparing to get some things ordered so i can get this thing off the bench and back in the bike .. THANKS !
LIVE IN EAST PA. OR NEW JERSEY THEN CHECK THIS OUT
