Results 1 to 10 of 10
Thread: 83 250r top end
    osoyoos bc canada
    1,057
    83 250r top end
    my freind blew his top end or his 250r he dosent whant to rebore he whants eather a big bore kit or a high comp pistion im haveing no luck finding a big bore kit on the internet what kits are good and where can i find one any help would be appeashiated
    is this what you're looking for? http://www.kustom-kraft.com/hondakits.html
    osoyoos bc canada
    1,057
    we need somthing we can buy and bolt on shipping the jug to the states waiting few weeks and shipping it back is a huge pain in the @$$ i thought they made bolt on kits for air cooled 250Rs but i cant find any
    i think wiseco makes big bore kits for the 83 models
    osoyoos bc canada
    1,057
    ya i saw them they dont come with the jug
    Oct 2009
    FF, Man.
    774
    there is nothing bolt on for the aircoolers, unless you find a vintage hondaline 300 or send the cylinder to kustom kraft. The Mugen 360 is another option but requires case, trans, and crank mods
    My 3WW Feedback Thread:
    Salut Gilles
    Southern MN
    1,875
    The mugen 360 kit is VERY rare to find. I see the hondaline 300 kits pop up on ebay once in a while, but I believe there are only 2 piston sizes available for it, then you need to mod the cylinder with machining, to fit a liquid cooled piston. I think you can bore the stocker out to the max, and it would become a 285cc, but the only place to find that big of a piston is through wossner I believe. I dont remember what size the stocker can be bored to, but wieseco only makes a piston up to 72mm - stock is 70, so you CAN go bigger than that with the wossner piston, and I beileve it is intended to fit a liquid motor. Check over at s dot com and you will find all the info you need for big bores, etc. Good luck!
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
    osoyoos bc canada
    1,057
    ya i thought finding that would be a pain in the @$$ ill talk to his and see what he whants to do. do they have a high comp pistion for 250Rs and do they add power that might be a option i know if hes going to rebuild he deffinatly whants more power than stock
    Aug 2004
    Ab Canada
    4,368
    You would be better, Cheaper, and quicker Just getting a good port job and setting up the head Properly, There's no "high compression" pistons for an old R...Wiseco's might add a hair more over a stocker,,The gain you feel in the seat of your pants would be from a fresh motor on that note, not the "high compression". You can bump the compression up working the head over.There is a few shops here that do Good work..if your interested Drop me a line.
    1985 Tri-Z-
    osoyoos bc canada
    1,057
    ill have to talk to him and see what he wants to do
