Whenever I start up my tri-z with the choke on it takes off on a very high idle almost as if the throttle was stuck wide open but isnt(have checked numerous times). If you leave the choke on the engine will keep revving and overheat,and the only way to shut the engine down is to turn the choke off which almost immediatly kills the engine. You can even pull the spark plug cap off and the engine will continue to run(how is this possible)? When I pull the spark plug out and look at it it has no signs of preignition, alittle sign of overheating, but thats to be expected from idling so high. My exhaust gasket leaks a little but I dont think that is the problem, I have checked for air leaks but found nothing. The engine is bored .10 over and I am running a mikuni vm 32mm roundslide carb which has a 470 main, #45 pilot, 2.0 air jet, 159 q-6 needle jet, 6dp17 jet needle, 3.0 throttle slide, pilot air screw 1.0 turns out, with a uni pod filter, the exhaust is also stock. If somebody could plese tell me why this is happening it would be greatly appreciated Tri-zs Rule!
