Thread: Fake Carbon Fiber 200X tank shrouds
    dksix's Avatar
    dksix is offline Just Too Addicted Arm chair racerJust too addicted
    Aug 2010
    North East Tennessee, USA
    610
    I didn't want to jack this thread http://www.3wheelerworld.com/showthr...7-carbon-fiber but wanted some input on this from you guys. I'm a department manager of a thermoforming department for a local company. Last week we had prototype request from a customer wanting parts formed from a fake carbon fiber finished polystyrene. I'm finishing my 84 200X in all black but have thought about a set of CF shrouds would break up the all black and give a nice look to the finished bike (when I ever get it finished). I checked with some folks here and even talked to that guy that appears to have been a scammer about doing a set for me but I've been unable to locate what I'm looking for. After having to sorce this material and will likely be stocking it at the plant now I gave soem thought of making my own shrouds. I can have a mold designed and made at the plant but I have 2 issues/questions about the shrouds. 1st, this is (IMO) pretty cheesy looking material. Not even close close to real CF but the flow looks good. 2nd, If I'm going to make them I think I'd like to get a set of the maier shrouds that are bigger than the OEM. Where would I be able to find a set of those bigger shrouds to patern off of, if I decide to try this. Here are some pics of the material I used, do you think it's too fake looking to look good?
    swifty's Avatar
    swifty is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    sabula iowa
    381
    i got my bigger 83-85 shrouds "super scoops" from dennis kirk for like $37 last year
    ACT NOW THINK LATER!
    current trikes owned
    minty 86 250sx my rider
    pauter flat track framed 110-123cc with custom goodies
    pauter mx framed 110-123cc with aftermarket goodies
    joker framed 90-108cc with front suspension
    2007 artic cat DVX 400
    dickson sprint framed 73 green us90 with 110 engine
    ATCrider42 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Iowa
    227
    I have a set of maier tank shrouds for a first gen 200x. Im not using them and would be willing to get rid of them for cheap. but the left side one is mishaped a little and the corner catches on the fork, which is why i decided to buy a set of stock shrouds. PM me if your interested. i can get you pics if you want, too.
    I don't think it looks too fake at all, seems like your well on your way
    dksix's Avatar
    Aug 2010
    610
    I'm not saying I'll do it, I may take the easy way out and just cover a set of OEM or super scoops with the carbon fiber vinyl sheeting. The mold I was using here was customer supplied and just for proof of concept. This particular material becomes a bit brittle for an off road application, IMO. These are not something I would sale, just be for me and I could keep some on hand to replace them as they break. The advantage for me is that none of this cost me any money, one advantage of being part of a small company. I would only make stuff I couldn't get through normal channels.
    Southern MN
    1,875
    Just do what I did, grab a piece of cardboard, and trace out a design for the shroud that you like. Cut it out, and hold it to the tank with the tank mounted, and turn the handlebar, to make sure it has enough clearance, if not, trim it a little at a time. Then for the other shroud, I just flipped the first one I cut around, and traced it, so it would be the same, only opposite. I cut mine out of aluminum sheet with a sheers, and a band saw to get the tight angles. They are nothing fancy, and just flat, not profiled, but they fit nicely, and give it a one off look, at least to me. I say go for it, I think it will look cool! Here are the only pics I have, wish I had a couple better ones.
ID:	114267Click image for larger version.
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
