Results 1 to 2 of 2
Thread: 185 pistons
    Jul 2003
    Las Vegas, NV
    124
    185 pistons
    Im rebuilding a 185 Ive had for awhile, was digging around parts I have accumulated for it, and came across a new piston..only difference is it's a dished pistons, the engine I just took apart has a domed (higher comp) piston. also the bore seems to be about 1mm smaller. I also have a few spare jugs and pistons I found, one is dished, and the other is domed...whats the deal? what models got what?
    also I was hope'n to swap the cam chain guides without removing anything from the bottom end...don't look like the case, I need to pull at least the stator/rotor.
    F.U.2 RACING
    Atc90, bandito frame
    Atc185 x2
    82 250 (300 kit)
    83 250R
    200ES Big red
    Atc200X (with lifan motor)
    6,817
    All the 185-200 model atc's came stock with the dished style piston from the factory except for the 200x it came with a flat top piston . if you have a domed piston its aftermarket .
