Thread: airfooler 300cc cylinder reliability
    Australia
    4
    Hi all, looking at sending my standard 83 Honda Barrel and head to the USA to get it sleeved with a thicker sleeve and bored to 76 mm. Although the head will be relieved to accomodate the larger bore diameter, Has any one had this done and are there any problems with the compression causing the cylinder head gasket to leak considering the Hondaline 300 item has seven head studs instead of 6.
    Aug 2005
    tulsa, oklahoma
    36
    go to air foolers.com all you questions will be answered there....
    Aug 2005
    tulsa, oklahoma
    36
    fyi there is not supost to be a space between air and foolers..
    Kentucky
    511
    If you haven't already check this site out also. They do good work.
    http://kustom-kraft.com/hondakits.html
    Lauderdale County, Alabama
    2,029
    Jethrow you're forgetting that this IS as three wheeler website, let the man ask what he wants here.
    Dec 2010
    shelbyville mi
    61
    i love my hondaline 300 kit!!!
    1984 250r
    300 big bore
    bassinni pipe
    boysen reeds
    34mm pj
    k&n pod
    1986 atc200x needs help
    2 banshees 1 for trails 1 for dune/drag racing
