so i was thinking about taking a 750 honda motor and craming it into a 1985 200x. just wanting to see what you guys thought. (it would be for going fast not trail riding)
If you are thinking a drag trike, then start your thinking with 2 stroke and go from there.
Nicholson 500x (Project)
Nicholson 185s
PK Racing Suspension 70
A+ Inc Suspension 70
AWS Aluminum 90 frame
a 200x frame/chassis isnt going to be any good for that motor and the motor itself is going to be heavy if your talking street bike. you cant build a drag bike with a small budget. if your new at fabrication and mounts then you need a 250r frame t convert for a cr500 motor then build the hell out of the motor and you will not be dissapointed one bit.you can ask the other members how it worked out.
This is my trike.
There are many like it, but this one is mine.
My trike is my best friend.
It is my life. I must master it, as I must master my life.
Without me my trike is useless.
Without my trike, I am useless.
I must roost faster than my enemy who is trying to beat me to the finish.
I must beat him before he beats me.
Before God I swear this creed.
My trike and myself are defenders of track.
We are the masters of keeping quads the losers.
So be it ... until there is no quad left.
ya i was just thinkin somthing to ride around here but i can see were there would be problems with weight.As far as the fabrication i think i could do that would like to try anyway. but thanks for the advice
I have built many streetbike conversions for people. They do Get it on perty good. But a true drag bike with an override and alky will useually smoke a streetbike conversion. So dont be suprized when that stock cyl 250r all streched out or banshee leaves ya.
Portland250r, the cr500 is in no way good for drag racing. The power is just in the wrong places. Your much better off with a 330, 350 or 370.
There's one similar to what you're talking about for sale around these parts...
http://pittsburgh.craigslist.org/rvs/2144218867.html
Just don't kink the down tubes..![]()
LED obsessed
2015 Yamaha FJ-09
well i tried to put a cb 350 motor in a 200x and ended up just scraping it because there was no way possible to make the motor even fit anywhere near in thet frame much less a 750!! not sayign it cant be done but it will look liek an abortion when done.
If it were me, like Vealmonkey said think 2 strokes. If you have some good old country junk yards chances are there will be an old Yamaha, Suzuki, or Kawi, large displacement 2 stroke street bike, that would be where I would start. Once I build my garage I am going to make one, there are some at the junk yard I have been eyeing. Also you would almost be better off modifying its cradle and making a custom swinger or adapting one, than trying to stuff it in a 200X frame. But some of the older 2 stroke street bike engines might fit in there. All sorts of sizes and not too heavy, compared to a similar displacement 4 stroke from the same era. Honda 750, great engine, just not in a trike, like the GS1000E trike. There's a Suzuki 3 cylinder 2 stroke just waiting to be made into a drag trike. Now to save up for the garage. Good luck on it, plus 2 cylinder and single cylinder 4 strokes are going to be lighter and make better power and weight than the CB750.
If you really want a drag trike with a streetbike engine, I have an old Hi Performance ATC frame that currently has mounts in it to take an rd350 engine, but I also have an h2750 streetbike that as long as you made new engine mounts, that would fit right in to the old Hi Performance frame. That 750 engine is a 3 cylinder, 2 stroke. Which would put you right in the ball park. Also you could use a snowmobile engine. Kawasaki made a 3 cylinder snowmobile engine that used a centrifugal clutch which could work as well.
Nicholson 185s
There are two of those H2750's at the junk yard. I need to get my hands on them. One is complete enough it might come back to life as the bike it once was.
I strongly disagree.This topic has come up alot lately. Mine is a great trail bike. It wheeles in 4 gears and will idle around all day.
The problem with the X frames is the center vertical tubes lay forward and have to be cut out and laid back to clear the carbs. This creates a weakness that can not be overcome. The R frames are already laid to the back. They would make a better plateform to start with.
FEEDBACK@ http://www.3wheelerworld.com/showthr...-for-Ironbnder
86 250R
86 350X
87 250sx
85 200x/cb350 custom
81 185s/200x/250r custom
79 atc 70
Mini-Trail z50, 110cc Pit Bike
and many multi-wheeled machines
http://www.youtube.com/watch?v=_TDauuPJ5aw
atc500r kills 4 mill cheetah.
This is my trike.
