Lowering the forks to compensate for 20 rear tires?
My 86 200x has 20in rear tires on. I think the front seems a little high, so I was wondering if anyone else has lowered to front forks a little bit for a more level ride with 20in rear tires. The front tire is a 23in tall. Any input is greatly appreaciated. I am only going to try it if others have doe it as well. Maybe slide the forks up an inch or so?
Jon
Ride: 1986 Honda ATC 200x
Following Mods Done:
-Anodized blue block-off plate
-Factory head light and master cylinder guard
-ITP mudlite SP rear tire/Chengshin turf tamer front
-DG reverse megaphone exhaust
-UNI airfilter
-Moose bars/Protaper Grips/MotionPRO twist Throttle
-CEET classic ATC blue seat cover (should of sent it to mosh :-(...)
-Tuned Carb with a 125 main jet
-COMPLETELY restored gas tank
-RED/WHITE PowerMadd Handguards
-1/4" thick aluminum swing arm skid plate!
