Thread: crf450 forks on 86 atc 250r possible?
    Nov 2010
    tennessee
    7
    What is involved in making this a reality i have the forks just no game plan on where to start.
    Tionesta, PA
    5,747
    the forks are way too long for an ATC250R. You would need custom triples as well as spacers / adapters for the front axle and brake rotor. You would then have to find someone to modify the forks (cut about 4" out of them). I personally would not try to adapt them to an ATC250R. Contact Jason Hall for the correct way to put inverts on your trike - he can hook you up with the parts and the know how.
    Aug 2009
    Georgia/USA
    I've been doing a big boy bike with 46 mm inverts. Its seems to be working out pretty good. I made custom trees to hold early 90's KYB inverts, then extended the swingarm to plus 4", this leveled the ride height. I also reworked the shock for longer travel. It now has over 12" of travel front and rear. I also have a 12" front rim that still lets me use a 23.5" tire, but now have room for a 10" brake disk instead of the 7.25" stock disk.
    audioworks04's Avatar
    Oct 2008
    Kansas City, KS
    332
    I know this is an old thread, but do you have any pics of your set up? What is your seat height now?
    86 atc250r stock sand only
    88 NX250 mint rainy day
