Thread: 84 200x mods?
    Jan 2011
    Michigan
    10
    84 200x mods?
    I going to start out slow on the upgrades for my ride. First i'm going to go through everything, fluids, cables, carb, lube. What kind of air filter do a want to get? Also I could use some rear tires if anyone has any recommendations.
    shortbus's Avatar
    shortbus is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Sep 2009
    maryland
    320
    Thats a clean trike, you could get a uni filter, jet kit, and a pipe, and maybe some razrs for the rear.
    83 suzuki alt125-sold
    86 350x-current-traded
    85 200x Current trike-sold
    85 200x-new trike
    83 atc 70/lifan 138
    99 cr80
    Jan 2011
    Michigan
    10
    Quote Originally Posted by shortbus View Post
    Thats a clean trike, you could get a unifilter, jet kit, and a pipe, and maybe some razrs for the rear.
    You need a jet kit to go with the pipe, correct? What type of perfomance will I gain from that.
    Mar 2007
    Texas
    5,045
    about 1-1.5hp and on that small engine that's a lot. before you do any performacne mods, you need to ensure the bike is able to handle it. change all fluids, check the rear swingarm for warn bearings, check the front and rear axels for bad bearings as well. ensure everythign is nice and tight. next do a compression test to see where the cyclinder is at. if it's too low, time to rebuild the top end.
    speaking of top ends, go ahead and check the valves and ensure they are correct.
    after all that, then look at performance.
    ________________
    https://www.mikesatvfix.com
    Jan 2011
    Michigan
    10
    Thats good advice. I'll check that stuff out. I'm going to have to wait till it gets a little warmer, not everyone lives in Texas. The wind chill is below 0 in Michigan right now.
