Thread: Another 350X cylinder head bites the dust :D
    I got one of the 2 heads I had to do done today. Just gotta put in the stainless studs.
    This hole (kinda hard to see it) was off center, and had used a 6mm fastner and it must have been stainless or something else; It was hard as a rock about half-way down the drilling path. Then I switched to a carbide end mill.The other holes were stock and no problem.
    Anyhow, these are the things that snap end mills, I can't drill them or the hole would be too far off of center. So, of course, the end mill snapped. I buy cheaper carbide end mills because I know this is gonna happen from time to time....... But, thats why I wish people would just send me the head. Many of you buy the trike like this but it's much harder to fix.
    I love when I get the ones with a stud welded to a stud
    Anyhow, here it is with 4 new helicoils installed:
    I always resurface the bottom and the intake flange mount just to remove any high spots:
    Shops open, keep em coming
    Jun 2009
    Tunkhannock,Pa
    904
    Always Good Work DC
    1985 200X
    66mm H&S Piston
    Little Bit Bigger Cam
    Bassani Exhaust
    1985 350X With Bassani Exhaust
    1983 Honda 200E (PARTING OUT!!!!)
    1985 Yamaha Tri-Zinger
    My Feedback Threadhttp://http://www.3wheelerworld.com/showthread.php?105185-Feedback-for-RodKnockRacing&highlight=RodKnockRacing
    scottyms's Avatar
    scottyms is offline At The Back Of The Pack Arm chair racerFirst time rider
    Feb 2006
    whats a service like that run? i've got one that im going to need done along with a 200x head...
    scotty
    They usually run about 100$ for the extraction of the old ones, 4 SS helicoil inserts and 4 new studs all included in that price.
    You cannot beat that price when just indicating in the head takes an hour and I have a 3000$ Bridgeport Mill.
    If something is hardened and inside the hole, you may have to pay me for a carbide endmill or whatever tool it takes to get it out.
    Sometimes I have to break tools to get it out and there's nothing I can do when it's half in aluminum and half in the stud or other fastner that got cobbled in there.
    I've done over 30 of these now............
    THANKS RODKNOCK!!!!!!!!!!!!
