Results 1 to 14 of 14
Thread: Broken ehhaust bolt inside cylinder,need help and advice
    redskinman's Avatar
    redskinman is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2010
    Cypress,Tx
    378
    Bought a 200x engine off fellow member here thats been bad news so far.After fixing clutch problem now I see one of the exhaust bolts is broken off in cylinder head.Looks like they tried to drill it out and have either broken off drill bit or extractor bit inside bolt.Am I screwed? I dont think another drill bit is going to drill through the old bit but I havent tried.Can you run these engines with just 1 exhaust bolt?
    82 250r-SOLD
    85 200x-SOLD
    85 Odyssey fl350-SOLD
    1989 Honda Pilot FL400
    1985 Yamaha 225dx
    ATCrider42 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Iowa
    227
    Try hittin up Dirtcrasher. He restores heads.
    Dec 2010
    Back in VA baby!!
    711
    You will need both bolts to seal the exhaust. Just take it down to a good machine shop, they'll get it fixed for you, and will have all the tools to do so. If you keep trying to get that out w/out the right stuff, you'll end up ruining the head.
    Spring, Texas
    450
    Man, you have had nothing but trouble with that motor since you got it. I can't tell from the pic, but I would think it would leak with just one bolt. Maybe not. I haven't tried it.
    85' 350x (newest addition)
    85' Tecate (Still dealing with electircal Issues!)
    85' Tri-Z (On the back burner)
    85' 200x (SOLD)
    Leave me Feedback: http://www.3wheelerworld.com/showthr...ack+for+ama009
    Aug 2007
    Burlington maine
    652
    I broke one off with a small tip left. I ended up welding a new 1/2 stud on. Id ont know if there is a enough room on yours though.
    1987 Honda 200X 90% way through frame up.
    1987 CR500R Motor, Soon to be a 540 ATC motor
    1986 250R frame, For now
    2008 Honda 700XX
    2004 KFX700 Torque monster!
    2011 Can-Am Commander 1000X
    Looking for misc Liquid R parts
    Nightmare's Avatar
    Nightmare is offline At The Back Of The Pack Arm chair racerFirst time rider
    lehigh valley, PA
    196
    The only way to drill through a bit or easy outs is carbide drillbit. NOT CHEAP!
    Ride: 1986 Honda ATC 200x
    Following Mods Done:
    -Anodized blue block-off plate
    -Factory head light and master cylinder guard
    -ITP mudlite SP rear tire/Chengshin turf tamer front
    -DG reverse megaphone exhaust
    -UNI airfilter
    -Moose bars/Protaper Grips/MotionPRO twist Throttle
    -CEET classic ATC blue seat cover (should of sent it to mosh :-(...)
    -Tuned Carb with a 125 main jet
    -COMPLETELY restored gas tank
    -RED/WHITE PowerMadd Handguards
    -1/4" thick aluminum swing arm skid plate!
    No they aren't cheap....... but your only other choice is another head.
    I have carbide and can get it out but you'll have to take it off and send it to me. Typically unless there is 1" deep of a tap or drill in there, I can get them out without it being a horror show.
    If it is in that deep, most machine shops would want a couple hundred bucks based on how many carbide drills they break and the setup and service time. I try to be less than half what a normal machine shop would cost you and I use a Bridgeport Mill/angle block and proper tooling once it's indicated in........
    Yours may have to be plugged and re-threaded.......
    Baltimore, MD
    6,088
    The only other alternative I know of is a machine shop with a machine that used a rod and it actually burns the old bolt and I think drill bits and taps out as well. I don't know anywhere that has one though. It's almost like a plasma cutter. And it's suppose to not mess with your threads. I would highly recommend DC though. He seems to enjoy the pain of these kinds of jobs. LOL
    Nicholson 500x (Project)
    Nicholson 185s
    PK Racing Suspension 70
    A+ Inc Suspension 70
    AWS Aluminum 90 frame
    If there is an easy out or a drill bit stuck in there you can shatter it with a and a punch. I would recommend sending it to DC though.
    Jan 2011
    dallas,nc
    87
    i have sent many parts out to have the tap blasted out... with great success... there is a guy here in nc thats local for me that does alot of the machine shops parts... for like 40 bucks he will an can blast the broke tap out...it uses electricity to break it apart.. i think its an edm machine if im not mistaken...
    i have saved a many of parts this way... id start by calling a few machine shops an asking if they know of anyone who can get taps out. they may be able to point ya in the right direction.
    also you could try to take a carbide endmill an a bridgeport an cut it out... i would try the machine first... im a machinist an have had luck cutting them out but man one slip an your finished lol..
    83ATC185S is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    May 2007
    Show Low, Arizona
    291
    redskinman's Avatar
    Dec 2010
    Cypress,Tx
    378
    I have another cylinder head that came with 3 wheeler when i bought it,engine not running..Im not a gearhead,but im not an idiot.Never messed with 4 strokes,have a 2 stroke which is a lot easier to work on.I purchased this engine because it was supposed to have a fresh rebuild with no problems.It had a clutch problem,now i find a broken stud.I went ahead and mounted pipe with 1 bolt to see if it would even crank and so far i havent been able to get it started
    82 250r-SOLD
    85 200x-SOLD
    1985 Yamaha 225dx
    Your broken bolt is not the reason it won't start. It doesn't sound like you're very happy with the seller.
    redskinman's Avatar
    Dec 2010
    Cypress,Tx
    378
    lol.Yeah,I know the bolt is not the reason it wont start,Im just saying add that to the list.No,I am not happy with the seller.Im waiting for him to respond before I slander his name across america.Plus another member recommended him,so I thought it would be ok
    82 250r-SOLD
    85 200x-SOLD
    1985 Yamaha 225dx
