Results 1 to 12 of 12
Thread: What is the stock HUB size for a 1st gen 200x
    ATCrider42 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Iowa
    227
    I beleive I bought a stock set of wheels and tires for my 200x and they don't fit the hubs that I have on my 200x currently. The hubs I have now appear to be 6 1/4" from lug to lug but the wheels I just bought appear to be 4 1/4" from lug to lug. What is the stock size hub for the 1st gen 200x?
ID:	114679Left: new wheels Right: current set-upClick image for larger version.
    6,804
    110mm is the stock size for a 200x .
    Iowa
    227
    What would 160mm be for then?
    6,804
    Not sure on the 160mm . Honda has a 155mm but no 160mm that I know of .
    Quote Originally Posted by ATCrider42 View Post
    Dec 2010
    Back in VA baby!!
    711
    Holy Tire Batman!! Those things looks huge. The picture of the hub you have there is not stock 200x, not sure what its off of. You're in luck thought, first gen 200x hubs are pretty common = cheap, you should have no trouble finding a good set. 83-84 250r hubs will also work.
    Jul 2008
    MD
    911
    Some Yamaha's have the same axle spline as the 200x and 300ex.. I had blaster rear hubs that fit right on the stock 1985 200x axle.
    Iowa
    227
    They are huge. They get great traction but are heavy and wide. So i bought a pair of stock wheels and then found that my hubs are not the stock size. So I wanna know what I have so i can sell the set of hubs that are on there now and I'm looking at some original sized hubs now. They may be 155mm on there now. I just did a quick measurement and they're about 6 1/4"
    Dec 2010
    Back in VA baby!!
    711
    You may have to search a bit, but somewhere on here I remember someone posting a chart with just the info you need, it had lug pattern, spline size, offset, for alot of ATVs. Also, if you ever plan on making a swap to the 9" rims, you may want to consider getting a set of 86-87 200x, or any 400ex rear hubs instead. They have the same lug pattern and spline sixe as yours, but also longer studs you'd need to put on the 9's. Only thing is you'd need to get are conical lug nuts for those hubs, as they are lug-centric, not hub-centric like the 1st gen hubs.
    Iowa
    227
    I'll probably stick with the 8" rims and get the stock hubs. I'm trying to keep this 200x "original" but we'll see how these wheels do. All i know now is 10" wide wheels is too wide for the 200x.
    Lancaster, PA
    1,738
    look like Kawasaki Mojave wheels
    1985 Tiger 250LC
    1985 Tiger 200LC
    1985 ATC 350X
    1985 ATC 200x
    1973 ATC 70 (resto project)
    and many more!!!
    Blue Line Graphics
    Iowa
    227
    Thanks, ill look it into it and see if they're from a kawasaki. I really don't want kawasaki parts on my Honda trike. Prolly the reason why I had to rebuild the engine this winter. It's kawasaki's fault.
    Iowa
    227
    I just noticed in the picture of my trike from the backend with the wheels off the ground, you can see the holes in the floor by the left wheel where I got pissed from trying to remove the swingarm bolt, and bashed the concrete floor with the . Dam, swingarm bolts.
