Results 1 to 15 of 19
Thread: How to get top speed out of my 200x
    sc
    8
    I bought an 85 200X a few months ago, I am now in the process of restoring it.
    I returned everything to factory settings and I was hitting 52-53 for a top speed.
    I was wondering if I changed the front/rear sprocket would it make much of a difference? I have found an 11, 12, and 13 tooth front sprocket for sale and as far as rear sprockets I've found a 38,39, and 40 tooth.
    Any help would be appreciated.
    Thanks Josh
    spoon's Avatar
    spoon is offline At The Back Of The Pack Arm chair racerFirst time rider
    Western Kentucky
    150
    Larger in the front. Smaller in the back. I have no experience on the 200x but I would imagine it would lose some puddin on the bottom end. Try larger tires on the back too.
    1986 350x stock
    1986 350x stock basket case
    1987 350x quad-powroll motor in a 250x frame
    1987 250x 250r a-arms extended chrome swinger
    1991 300x 250x with a 300ex cylinder-my beater
    1993 330ex under construction-ex wife stole it!
    1985 250SX bought from 250sxman
    1985 250SX needs a few parts
    1988 350x 250x frame stock 350x motor
    2003 Yamaha Road Star Silverado
    I gotta quit buying these things.
    osoyoos bc canada
    1,057
    2mm bigger carb xr200 head
    ailll1's Avatar
    ailll1 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2009
    Québec
    405
    Quote Originally Posted by spoon View Post
    Smaller in the front. Larger in the back. I have no experience on the 200x but I would imagine it would lose some puddin on the bottom end. Try larger tires on the back too.
    No thats exactly what he doesnt want to do if he wants to gain top speed. Bigger up front and smaller at the back sproket.
    1985 ATC250sx
    1984 ATC200s
    1984 ATC200x
    HONDAS FOR LIFE!!!
    Crest California
    3,014
    ^Yeah I was about to say. And I wouldn't go over 22" for rear tires on it, since it's more of a sport machine.
    LED obsessed
    2015 Yamaha FJ-09
    spoon's Avatar
    Western Kentucky
    150
    dammit!! ok fixed it.
    1986 350x stock
    Quote Originally Posted by bcredneck View Post
    That is going to do absolutely nothing for his top speed.
    Mar 2007
    Texas
    5,045
    bigger carb gices more power. more power means more top end.
    ________________
    https://www.mikesatvfix.com
    Xfile's Avatar
    Xfile is offline Just Too Addicted Arm chair racerJust too addicted
    Apr 2007
    Shiocton, Wisconsin
    700
    2mm is jack....you need to run a 28/29 (can't remember exact size) from a XR200. you also need to use the early 80's XR200 manifold to match the larger carb size with the 200x head intake passage. I don't think running a xr 200 head is going to do anything for you, I'm pretty sure the compression difference came from a different piston design, not the head itself..
    Don't worry...just run watcha brung...
    Mar 2007
    Texas
    5,045
    yea xr200 head is the same specs as 200x. piston is only .5 more than than 200x. your best bet is a wiseco piston, larger cam and 26mm carb from a xr200. (they were 26mm vs 24mm 200x) this is a cheap way. if you want expensive, i can go there too.
    ________________
    South Wales, U.K.
    525
    You can change the gearing with the sprockets and fit bigger tyres but if you gear it up too far you'll strugle for power, so you'll have to do some mods to make more hp!!
    If it ain't sideways......what's the point!!
    86' Honda Atc 250R - under restoration
    10' Polaris Outlaw 525s - my XC race quad
    05' ATK 640 "Cannondale" xc racer
    00' Banshee 350
    Quote Originally Posted by oscarmayer View Post
    Top speed Oscar. He hasn't asked a thing about the motor.
    Xfile's Avatar
    Apr 2007
    Shiocton, Wisconsin
    700
    If we are counting out motor mods...I guess I would just leave it like it is...whats the difference if it goes 53 or 55. If someone asks you how fast it goes...just say somewhere in the "50's" and your covered.
    Xfile's Avatar
    Apr 2007
    Shiocton, Wisconsin
    700
    My bad ,26mm is the XR 200 carb...but there are other mods that go along with this to make it work correctly. I believe the is an dirt wheels article about it over on 3wheeler.com or something like that. It lists everything you need...the early 80's xr200 manifold is one of them. the stock 200x manifold has a smaller ID.
    sc
    8
    I appreciate the help, I need to buy another engine to do mods on,
    Now I am just going to have to find a place to ride it in SC
    josh
