WOW Neighbor, is that the engine you were going to troubleshoot today. If so I guess the compression test did not go well.
If the case is solid and sealed up behind the bushing, pack it with grease and gentley tap a rod or bolt the exact size of the starter shaft into the bushing hole. The grease will pressure up behind the bushing and it will pop right out. This always works to remove pilot bushings from standard flywheels in vehicles. I keep old pilot shafts around just for this. This is the same principle and it should work. Keep adding grease as neccessary. The rod should kinda bounce from the pressure of the grease when you hit it. It should not feel solid but spongy. Keep tapping and adding grease until the bushing falls out.
FEEDBACK@ http://www.3wheelerworld.com/showthr...-for-Ironbnder
86 250R
86 350X
87 250sx
85 200x/cb350 custom
81 185s/200x/250r custom
79 atc 70
Mini-Trail z50, 110cc Pit Bike
and many multi-wheeled machines
blind bearing puller....... probably be able to borrow one from the local auto store if irons method doesn't work for you. That is a pretty crafty idea though....
ironbuilder,thats not my engine,found that one on ebay,just happen to have the same bushing busted up as mine.but yeah i went to do the compression test today and the engine wouldnt turn over,come to find out it wasnt the starter but the bushing that holds the asm gear shaft,the shaft kicks out of place and wont turn the flywheel over.i gonna try to find that bushing locally but will prob have to end up ordering one.
Signature pic removed,becuase of no helmet.
