Results 1 to 15 of 30
Thread: 1986 honda ATC 200x AXLE KITS? AFTERMARKET AXLE??? DUREBLUE OR G-FORCE AXLE???
    New york
    583
    Hello everyone, I rode my '86 atc 200x last friday and got one left hub is stripped and it kinda ruined now.
    Does the axle's company selling any rear aftermarket for it? like Dure blue, G-Force axle?? I seen them selling a lot axles for Honda 250x, 300ex, 400EX & 450R quads. I don't know if they selling one for mine 86 200x? If yes, then let me know so i will buy them
    Thanks Kev.
    Willamstown PA
    5,824
    i dont think anyone makes a aftermarket axle for a 86/87 200x anymore. if im wrong im sorry. you could do what i did and have a 300ex style swingarm made for a 200x, (would be easier on 86-87) run nice new billet dual row carriers and 2+2 axle. the axle i got is a 2+4 dura blue on my 300ex.
    hreatv.com could tell you more about it...he build mine. solved all my issues of finding 200x axles.
    New york
    583
    I hope someone here on 3wheelerworld will know more about it than i do.
    Hey Oldskool83, Do you meant a COMPLETE REAR END OF 300EX and put it onto to rear subframe onto to an 86 atc 200x? how does that works? Sounds preety neat to me.
    Xfile's Avatar
    Xfile is offline Just Too Addicted Arm chair racerJust too addicted
    Apr 2007
    Shiocton, Wisconsin
    700
    You can swap to a 1983-84 atc 250R axle...you need to mod the 86-87X bearing carrier a bit or use an aftermarket bearing carrier. The 83-84 axle is a bit wider too. I am doing the swap now...but some people on here have done it already and should be able to provide you with more details and some pictures.
    Don't worry...just run watcha brung...
    Ohio
    593
    I've seen 300ex swap in, and I know 40mm raptor,and something else works.
    scottyms's Avatar
    scottyms is offline At The Back Of The Pack Arm chair racerFirst time rider
    Feb 2006
    New 87 200x axle On eBay... 500 Is less than a swingarm conversion will be
    current line up:
    86 KXT250 Tecate
    87 KXT250 Tecate
    86 ATC350X
    87 ATC200X
    85 YTM200
    and about a dozen more in parts...
    There was a set up on EBAY a year ago that had a 300EX carrier and axle in the stock swinger. Whether it slid right in or he had to machine some things, I don't know but it was a clean swap.
    83-84R axle fits perfect, must use 83/84 brake rotor and 2mm smaller ID axle seals. It also limits your sprocket choices unless you go to sprocket specialists.
    New york
    583
    300EX rear axle and carrier too??? umm interesting.. I will try either way of those 300EX or 250r axle also? how about a complete set up from a stock REAR END OF 300EX and bolt right onto to an 86 atc 200x?? will that works also?? any tips??????
    Thanks.
    Xfile's Avatar
    Apr 2007
    Shiocton, Wisconsin
    700
    Hi DC, what was the reason that you had to use the 83-84R brake disk hub? I was planning on using my 86X brake hub on my conversion. If you use an 83-85 200X seal on the sprocket side and a 86X seal on the brake rotor side the seal IDs and ODs will be correct for the R axle/86X brake hub. Other than that, the 86X brake hub slides right on the R axle and seems to be about the same width as the 83-84 R brake hub.....Have you found another reason it will not work? thanks..
    Aug 2007
    Burlington maine
    652
    It was close to a direct bolt in. The swinger was stock and the carrier was aftermarket. I bought part of that set up for the skid. I still have the swinger bolt.
    1987 Honda 200X 90% way through frame up.
    1987 CR500R Motor, Soon to be a 540 ATC motor
    1986 250R frame, For now
    2008 Honda 700XX
    2004 KFX700 Torque monster!
    2011 Can-Am Commander 1000X
    Looking for misc Liquid R parts
    NC
    907
    300ex swinger will not fit without heavily modifying it and it is just a bit shorter than the 200x. 300ex swinger is wider both front and back. 300ex axle carrier is longer but does fit properly diameter wise in the 200x swinger. I'm sure it could be made to work pretty easy. 300ex axle is longer too - 1" or so.
    Aug 2007
    Burlington maine
    652
    Those pix are worth 100 days of searching.
    2008 Honda 700XX
    The guy selling it had an 86 200X swinger and 300EX carrier/axle; Looked like a perfect set up!!
    In your picture the swingers look similar or just a few MM's wider than the X in the carrier department; Or am I wrong??
    X-File, both seals have to be 2MM smaller ID. The 200X rotor hub would not fit on the 83/84R axle or I'm crazy........... I remember waiting 2 weeks to get the hub and it's a 3 bolt so I could use that TUSK SS rotor I think the 200X was a 4 bolt, I'd have to look at my notes...
    Arizona
    506
    I remember the one dirtcrasher is talking about. I saved it because I was wanting to maybe do the same thing sometime. See below:
    ▪ One 1986 200X rear swingarm
    ▪ Reflective Chrome powder coat on swingarm
    ▪ New 1986 200X Honda OEM Chain Slider
    ▪ New 1986 200X DG Aluminum Skid Plate
    ▪ New 1986 200X All Balls and Honda OEM rebuild parts
    ▪ New 300EX RAD Mfg Bearing Carrier
    ◦ BC-H8
    ◦ Blue Anodized
    ▪ New 300EX Rear Dura Blue X-33 Billet Axle
    ◦ #20-2145ex.
    ◦ +2/+7.
    ▪ New 300EX Dura Blue Anti-Fade Brake Hub
    ◦ #20-1601
    ▪ New Honda 300EX OEM 37mm rear outer axle clip
    ▪ New Honda 300EX OEM Rear Brake Caliper Assembly
    ▪ New Honda 300EX OEM Brake Pads
    ▪ New RAD Mfg Rear 300EX Brake Rotor
    ◦ #H-2
    ◦ Stainless Steel
    Aug 2007
    Burlington maine
    652
    Thats my skid plate, LOL
    2008 Honda 700XX
