Thread: 83atc250r o recenly changed fuels whats the best ratio
    Jan 2011
    Laurel DE
    20
    I chanhed fuels from 50:1 to 30:1 but it smokes alott more since I switched what is the best fuel mix ratio for 83 atc250r???
    Auto_Demon's Avatar
    Auto_Demon is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Stonewall, Manitoba
    290
    i use 50:1 in my 83r and i put the needle in the carb to its leanest setting and it runs like a dream
    ktmbk's Avatar
    ktmbk is offline At The Back Of The Pack Arm chair racerFirst time rider
    Long Island
    154
    I tried a few and here the results I found worked best for my R:
    1/2 cam 2 - 1/2 pump gas, golden spectro premix, 20:1 mixture.
    it does smoke a little more than other ratio's, and you do need to warm her up to clean her out before beating on her, but I haven't lost an engine since I went with that formula. I think the 20-1 ratio is what is recommended from honda anyway - at least that's what the sticker on the tank said. whatever you end up with remember to adjust your carb as needed.
    Auto_Demon's Avatar
    Stonewall, Manitoba
    290
    Quote Originally Posted by ktmbk View Post
    ya it doesnt realy matter as much about the mixture as long as you tune the carb right, the old 2 strokes arent as picky as todays for mixture
    Baltimore, MD
    6,088
    What does the premix oil maker recommend? Some of the makers suggest the best mix ratio. If the maker doesn't recommend a ratio, then follow what the manual says.
    Nicholson 500x (Project)
    Nicholson 185s
    PK Racing Suspension 70
    A+ Inc Suspension 70
    AWS Aluminum 90 frame
