Thread: throttle sticking on 83 250r
    Jan 2011
    Laurel DE
    20
    I was riding and my throttle was stuck and I couldn't get it unstuck and had to shut it off bfor it blew what's the prolem???
    Iprefer3's Avatar
    Iprefer3 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2010
    Glendale AZ
    441
    Could be a number of things. First check your throttle cable routing (make sure it's not binding up when you turn the wheel side to side). Second pop off the top of the carb and pull out the slide and make sure it's clean (if not clean it). Thirdly loosen the carb boot clamps and turn the carb where you can see down inside the top and make sure the slide guide didn't break off. Lastly make sure your throttle springs back when you turn it (twist) or press it (thumb). If all that checks out...could have been an air leak.
    If trikes are so dangerous how could I possibly still be riding them after 12 years?
    Baltimore, MD
    6,088
    Not sure, but I think DE means Delaware? If it does, you may have noticed the freezing temps outside. You could have moisture inside your throttle cable and it may have frozen while you had the throttle open? Just a guess. LOL Seriously though, your cable could have frozen open with the temps.
    Nicholson 500x (Project)
    Nicholson 185s
    PK Racing Suspension 70
    A+ Inc Suspension 70
    AWS Aluminum 90 frame
    beaver bank N.S Canada
    555
    I had that happen on my 81 250r. I lubed the cable and have not had a problem
    Jan 2011
    Laurel DE
    20
    Yea true its pretty freezing out hear and yea I think that's what happen cuz it was raining and it changed to snow and it might of froze water and got stuck
