Results 1 to 3 of 3
Thread: Kicker shaft for 86 200x.... Breakage ?
    Nightmare's Avatar
    Nightmare is offline At The Back Of The Pack Arm chair racerFirst time rider
    lehigh valley, PA
    196
    I keep hearing about these kicker shafts snapping. How common is this? Also, If I go to a wiseco high comp. .20 piston will I be ok? Either way Its a stock piston set-up with the correct amount of compression. It seems like it would be awfully had to snap a kicker shaft on this thing. I am sure it does not have the 19mm shaft, but I'll have to check tomarrow morning. Does anyone know where or who may have the 19mm 87 kicker shaft? I suppose I would need the 97 clutch cover to, or have to machine the 86 clutch cover to allow an 87 kicker shaft seal? Any input?
    Ride: 1986 Honda ATC 200x
    Following Mods Done:
    -Anodized blue block-off plate
    -Factory head light and master cylinder guard
    -ITP mudlite SP rear tire/Chengshin turf tamer front
    -DG reverse megaphone exhaust
    -UNI airfilter
    -Moose bars/Protaper Grips/MotionPRO twist Throttle
    -CEET classic ATC blue seat cover (should of sent it to mosh :-(...)
    -Tuned Carb with a 125 main jet
    -COMPLETELY restored gas tank
    -RED/WHITE PowerMadd Handguards
    -1/4" thick aluminum swing arm skid plate!
    Ohio
    593
    For the swap you would need the cover or machine it yes.
    I havn't snapped mine yet, and it's been abused alot over the years. I am worried about it, as i've seen one that was snapped. I'm about to install my decompression cable, and that should ease the problem.
    They snap easy. I buy up every 87 shaft I see.
    Running the decompression cable is a must, it's there for a reason.
