Well as it turns out in order to fix the kickstart gear on my 85 200x the
motor has to come apart, It runs great but this will be an opportunity to
refresh it a little if needed,
any info on rebuild recommendations, or case splitting tips are appreciated
what kind of pistons, bearings, performance upgrades are recommended?
Thank you for any info forum members,
I will take pictures of this as I progress, It may help someone with
the same project in the future.
-Sean
s away unless they are plastic and no screwdriver prying on any case oil sealing surfaces. I put everything in ziplock bags and take notes - EX. shim on each side, washer faces out etc., etc. You never know when this will go back together - anything can happen and I always forget!
