Thread: 85 ATC 250R Gas Tank Shroud Bolt Question
    BWard's Avatar
    BWard is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Sep 2009
    Kyles Ford, TN United States
    402
    I was removing my shrouds off my 85 R Gas Tank and the last bottom bolt, the nut decided to spin in the tank, How do you hold the nut so you can remove the bolt??? My shroud is original and in very good condition so I do not want to break it. I tried holding it with a flat blad screw driver, Now I'm thinking of cutting the bolt.
    Thanks for your help.
    Brian
    osoyoos bc canada
    1,057
    drill the center of the bolt out so you dont wreak it thats what i do
    BWard's Avatar
    Sep 2009
    402
    Thanks, I'll give it a shot
    Riding Wheelers Again
    85 Honda ATC 250R
    86 Honda ATC 350X
    85 Tri-Z
    Future Rides
    1985 Honda ATC 250R, be a Woods Rider
    Past Rides
    85 Honda SELVY ATC 250RSold It
    1983 Honda ATC 200x Raced Pro Mod
    1984 Selvy Tecate 200 Crazy Fast 3 Wheeler
    1985 Yamaha Tri-Z Raced Pro Mod
    1986 Honda TRX 250R Raced Pro Mod
    3B Lightning Yamaha YZ250 Based Three Wheeler
    friend owns and raced it
    Looking for 85-86 250R, 85-86 350x, Tri-Z
    Low Profile Fenders
    BWard's Avatar
    Sep 2009
    402
    has anyone ever come up with a fix to this problem of the shroud nut spinning in the tank??
    So when you reassemble you can use that nut??
    I have a nut that has split and a piece of the thread gone, still works just can't really torque on it.
    I would like to fix it properly for the next time I may need to remove shroud.
    This is NOT the one that is spinning
    The one that is spinning is still sitting on the shelf.
    85 Honda ATC 250R
    86 Honda ATC 350X
    85 Tri-Z
    Future Rides
    Past Rides
    Low Profile Fenders
